1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-22-2014, 06:47 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
How to change tie rods (w/ pics!)
Old 07-03-2011, 08:16 AM
martin123456789's Avatar
martin123456789
martin123456789 is offline
I noticed this:
And it also smelled like burned oil, to my surprise it turned out to be this:
Yes, one of the boots busted.
And upon, jacking up the vehicle there seemed to be a little loose in that tie rod when pushing/pulling the passenger side tire.
Just to be safe, both tie rods will be changed, the other one looks like:
Notice how cracked/dry the rubber is? I will start spraying these(and the other rubber boots) with silicon at every oil change from now on.
Purchase some new tie rods:
Lift up vehicle using notches on the radius arms, and position some axle stands, safety first.
Before doing anything, measure everything!
Counting the number of turns when taking off a tie rod end is not going to work, one of them turns in the wrong way. Measure the distance instead, 1 turn will make a noticeable distance difference.
I would also advice on measuring the total length of the tie rod bar, this should allow you to put it back pretty much like it was.
Now spray plenty of this stuff:
Try to drown these:
You might want to secure the steering wheel with a seat belt, just in case.
Now, undo the bolt on the passenger side, use a puller and/or a hammer to separate them. Then unbolt the driver side, same strategy. (Sorry no pictures)
Now that you have tie rod bar in your hands, put it into a vice to undo one end.
Inspect, mine had this:
Spray more of that stuff:
Now with the adjusters loose (take that bolt out!), try to pry this a little, and use a pipe wrench to unscrew the tie rod. (If you feel like counting the number of turns be my guest, good luck)
Now put the new end on, and turn the same exact number of turns, or better yet just measure the gap (this is assuming the new part is exactly like the old part):
Once both ends are done, re-installation is easy.
Just bolt it up, I think the torque specs are 85lb-ft for the tie rod ends and 41lb-ft for the adjusters but double check this, I could be wrong.
Measure the distance between the front tires in the front and in the back, it should be about the same.
Now it's time to get an alignment and you're done!
Old 07-03-2011, 09:03 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Excellent thread... pics are perfect. Rep's given!
Old 07-03-2011, 09:25 AM
sammy77's Avatar
sammy77
sammy77 is offline
Nice job...
Old 07-03-2011, 09:29 AM
jd58980's Avatar
jd58980
jd58980 is offline
Nice Write up..Reps given
Old 07-03-2011, 09:30 AM
sddesigns's Avatar
sddesigns
sddesigns is offline
Great Job and nice picture progress!
reps given!
Old 07-03-2011, 02:29 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
sweet write up nice pics
what year is your truck my tie rods alittle diff but thats ok still about the same work
the only boot thats leaking is the Tie rod at the steering box
I was going to count the turns and also try and mark its position on the steering linkage
funny how 1-2 turns one way or another can throw alignment off
funny I measured the distance same way you did on my car and with some driveing and adjustment I got it right on It was easy but also only had one tire wearing funny so I knew I had to adjust that one by the time I had it going straight down the road the steeringwheel ended up centered perfict
Old 07-03-2011, 02:35 PM
martin123456789
I have a 2005 F250, this should apply till 07.
However, it's likely to be very similar for other years.
Old 07-03-2011, 02:36 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Nice Write-Up! Reps sent!
Old 07-03-2011, 04:50 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
Another nice write up with pics! Thanks!
I tried to rep ya but I just repped ya in your heated seat thread so I gotta spread it around first.
Old 07-04-2011, 01:11 AM
Fallguy2004's Avatar
Fallguy2004
Fallguy2004 is offline
Great write up. Question though, your truck appears to not have a steering stabilizer. Also noticed my truck doesn't have one while doing my front end.
Whats the deal here?
Old 07-04-2011, 06:42 AM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
Great job and write up. I have one that is going to need to be changed out soon myself.
Old 07-04-2011, 02:36 PM
martin123456789
Here's a better angle, should be easier to see like this.
*Notice the valve on the oil pan
Old 07-04-2011, 02:41 PM
martin123456789
Make sure the rubber is still good on the other one.
And if the other one goes right after, you have pay the shipping fee, tear it down again & get an alignment.
Might as well do both?
Btw, total cost was 100$ per tie rod & 40$ shipping. -> 240$
(No alignment was done yet..)
Old 07-04-2011, 02:44 PM
senix's Avatar
senix
senix is offline
I will just do both at the same time. I had one bend on me slightly. Still within specs for now but I know it is not wearing evenly
Old 12-14-2011, 04:25 PM
kidoo's Avatar
kidoo
kidoo is offline
HI, I am changing the Right one with Moog, mine is a 2006 and looks pretty well the same, the left looks OK but maybe I should do both.
What is the Moog number for the Left side (driver), I could not get a number. They want $184.00 for one here.
I got the Right one replaced 16 month ago with a ford Motorcrap, 11,000 miles on it and it's got a gook half inch play now, what a crarp. I also replaced the left hand ball joint, the upper one had quite a bit of play, may be it scrapped the tie rod??
Quick Reply: How to change tie rods (w/ pics!)
