F350 Hot Rod???
Old 07-03-2011, 12:47 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
F350 Hot Rod???
Just thought I'd post a funny picture of my truck as it sits right now.
First take a 2wd with stock suspension and then add a set of factory 4" lift blocks in the rear.
With 3" body lift:
Body lift removed:
Stage 1 of 4x4 conversion complete...
Old 07-03-2011, 01:33 AM
joe_13894's Avatar
joe_13894
joe_13894 is offline
How are you doing the front end? Did you burn the shackle mounts off the old truck to put them on your 95?
Old 07-03-2011, 08:39 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
You need some slicks on the back now 38" slicks for the back
Old 07-03-2011, 08:50 AM
Talyn's Avatar
Talyn
Talyn is offline
My truck is kinda like that, not as aggressive though. drives me nuts!
Specially cause my rear springs are so heavy that I cannot make them budge no matter what I put in the bed or hook up to it.
Old 07-03-2011, 01:02 PM
Brown Falcon
I was originally going to use the front springs and shackle mounts from the old truck, but they are a little rusty and I can sell it for more if I keep it in one piece.
Plan right now is to do a RSK (Reverse Shackle Kit) up front, and I'm working out a deal on some front springs from a '97 F350. New shackles and rear brackets for the springs are gonna cost about $100 from Rock Auto.
When I did my SRW conversion I lost the overload springs. My main leaf packs are pretty soft but now I've got the blocks and the overloads from my '87 on there. Still rides pretty good but when I load up the back it won't squat as much.
Old 07-04-2011, 04:38 PM
Brown Falcon
Updated the pics at the top. With and without the body lift. I'm glad the body lift is off, but now I want to get my 4x4 conversion done so the front end will be level with the rear.
Old 07-04-2011, 06:41 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Fullcrew7.3 is offline
That is Soooooo 70's. You'll fall in love with the truck all over again.
Old 07-05-2011, 02:44 AM
joe_13894's Avatar
joe_13894
Hmmm, maybe I need those blocks!
My truck is only down a tiny bit at the back when the camper is on, but my extension drags big time when I go through a dip. If the thing was rear high the extension would never hit. Then again, I'd be sleeping head down...
Old 07-05-2011, 09:11 AM
Brown Falcon
My dad's extension is pretty low on his camper as well. Not sure if he found a solution for it yet.
You could always get some large wedge pillows.
Or just get some smaller blocks for the rear, maybe 2" instead of 4"
GreatNorthWoods
21
10-10-2012 09:46 AM
gquinn8516
104
12-02-2010 07:16 AM
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
Red Ford Truck
Ontario Chapter
27
07-26-2009 08:12 AM
ckrichard
06-29-2004 08:56 AM
Quick Reply: F350 Hot Rod???
