Old 11-19-2014, 02:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Fuel Door Broken
Old 07-02-2011, 11:58 PM
CountryBudTX's Avatar
CountryBudTX
CountryBudTX is offline
Fuel Door Broken
On a roadtrip, went to fuel up and when I was done... the fuel door would not pull itself closed. I pushed on it, whatever spring or band was there pulling it closed is no longer functioning. 37500 miles on an '09.
Has anyone else had any issues? This really bothers me because of the no fuel cap design. Will have to take it to the dealer when I get home and find out what's the solution.
Old 07-03-2011, 08:07 AM
efx4's Avatar
efx4
efx4 is offline
I haven't heard of this happening before but it certainly can happen as it has happened to you.
Old 07-03-2011, 08:46 AM
CountryBudTX
Could be that mine is "ahead of the curve" like it was on the seat covers... had 2 replacements before the TSB came out.
Old 07-03-2011, 12:16 PM
NotMyHusbandsF150's Avatar
NotMyHusbandsF150
NotMyHusbandsF150 is offline
What was wrong with your seat covers?
Honestly, I've never heard of a broken fuel door in my life... surely it is covered under warranty. Or you could replace it with one of those fancy chrome cap looking things.
The actual door has nothing to do with the "no-cap" system, from what I understand, so I don't think it will affect fuel pressure or get water in the system - if it does worry you much, this is why God gave us duct tape
Old 07-03-2011, 12:36 PM
CountryBudTX
The seat covers came loose at the front of the seat bottom. The door just flaps in the wind...
Old 07-03-2011, 07:43 PM
FORD COASTIE's Avatar
FORD COASTIE
FORD COASTIE is offline
Supporter of Patriotism
Received 2,363 Likes on 1,709 Posts
This happened to my 2004 about 2 years ago. The fuel door housing had to be replaced. The total was $136.00 at the dealership.
Old 12-09-2011, 03:04 PM
pilot10's Avatar
pilot10
pilot10 is offline
Mine has tape to stop this from happening. Started last night; Went to close the fuel door and I felt a very slight stuttering to the spring action when I push on it. And now the spring action is askew. Also when you push the door closed it is no longer centered in the hole, off by an 1/8".
Was this ever resolved. Dealer price of $50-$80 depending on Vin# for a replacement part- excluding paint to match door.
Anyone know what's going on? Are there any lotech solutions not involving duct tape - on the outside at least?
So far the truck has been a champ- One warranty service 2 weeks ago for condensation in one brake light assembly, and whose to say if that wasn't the result of trailering damage. Unfortunately just turned 39k on the odometer today so out of warranty- we went on vacation, Alot
thanks,
Tim
Old 12-09-2011, 04:33 PM
garyrox5's Avatar
garyrox5
garyrox5 is offline
the filler door on my 2004 FX4 had the spring spindle break off, searched the internet Ford parts places, ordered one, cost was insignificant, actual cover slides off , slid it back on the new cover and good as new. Hopefully the covers on the new F150's slide off as well.
Old 12-09-2011, 06:12 PM
pilot10's Avatar
pilot10
pilot10 is offline
I will search online. I did read somewhere else that the covers just slide off.
Thanks
Old 10-01-2014, 06:08 PM
Ody1964's Avatar
Ody1964
Ody1964 is offline
I realize this is an old post, but recently had this happen on my 2010 truck. Bought the new gas filler part on Amazon for $42 and installed it in 10 minutes. Very easy to do. Remove 3 screws. Use a screw driver to pry out the old one. Remove the outside plate and transfer to the new piece. Put the new one in place and retighten the 3 screws. Never had to crawl under the truck.
Old 10-01-2014, 06:13 PM
Ody1964's Avatar
Ody1964
Ody1964 is offline
Here are some pictures to help with the instructions
This one shows the tab you need to pry out a little to remove the door in order to put it on the new "housing"
This one shows the 3 screws you need to remove
This is the part I ordered off Amazon
This is the old one. When you remove it pry on the top right and bottom right sides first. Then is should swing out. After removing it, I realized my spring didn't break, there is a plastic piece that loosened up. I pushed it back together with a water pump pliers and I can now reuse this one if the new one I put in ever breaks. I can't stress how easy this was to replace. I am a desk jockey for a living and it took 10 minutes.
Old 10-01-2014, 08:06 PM
klasher's Avatar
klasher
klasher is offline
I did the same after finding a video online. I have to do it again after over a year, but cheaper than a new one.
Old 10-02-2014, 10:36 AM
F150&EB's Avatar
F150&EB
F150&EB is offline
Glad to know there's a cheap & easy fix for this. When I had my oil changed at a local dealership recently, the service writer mentioned they replace the gas doors often. He warned me not to let the door "slam" shut, but to gingerly close it. Apparently the slamming causes the spring to pop off. He said it was a $250 repair...
Old 10-02-2014, 07:44 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
I had this happen on my 2012 a couple months ago. After taking the assembly apart I found that the rod that holds the door to the spring assembly backed out and out of index. I indexed it and pushed the rod back down and all is well for now. If it does it again I will install a small screw or cotter pin or something to keep it in place.
Old 07-16-2015, 04:21 AM
mikesxpress's Avatar
mikesxpress
mikesxpress is offline
I had the rod also back out on my 2011 yesterday. I reassembled the unit and drilled/tapped the end of the rod with a 6-32 UNC thread and installed a screw/washer to retain the rod. The top of the molded retainer for the spring on the housing was also cracked partially off so I removed the remaining piece and drilled/tapped the upright with an 8-32 UNC thread and installed a socket head cap screw/washer. Both received thread locker and now it's better than new.
Quick Reply: Fuel Door Broken
