Heated seats not working?? Here's why mine don't work (Pics & re-assembly details) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-02-2011, 04:24 PM
martin123456789 martin123456789 is offline
martin123456789 is gaining momentum as a positive member of FTE.martin123456789 is gaining momentum as a positive member of FTE.
After like 2 hours of tearing down...
Here why the resistance of my heating element is infinity
I'll take pictures of the painful reassembly and post them.
Old 07-02-2011, 04:26 PM
Part number: ASH Ford P131/U137
603290
04 fs ch th
Can I buy just the element or do I have to buy the whole seat cushion???
Old 07-02-2011, 09:00 PM
Here's how to re-assemble that
Solder your heater element, then verify the resistance
I got this:
Glue the element back on
Like so:
This was the tricky part... when disassembling, I just cut all of them to make it easier, now to put this back together, I'll just use tie wraps (and I'll cut them too if I ever need to undo this again)
Place all the tie wraps, make sure you get the squares on the outer sides so you're not tightening them reverse to what makes sense
This is what I mean, the square end is on the outside.
Just tighten them up, cut the end, rotate them so that the squares on below.
Insert the back support and back heater wires in there, they will be in the back of the joint. Push in, move it left, it should pop in
Screw this first
Put back all the edges (black plastic retention clips, it's easier if you do bottom, left, top then right (i think))
Pass the seatbelt wire through, bolt the seat belt back on the side
Rebolt the hinge
Plug the wires back in & secure them
To put the plastic back, just get the lever through then it's easy
Make sure you put that clip in the back behind the metal piece
Two screws
That one
Two more under the seat that go on the side plastic, clip in the back.
Plug all the wires & make sure the seat can freely move.
You're done!
Old 07-03-2011, 12:31 AM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Great write up and pics!! This will definitely help someone down the line. Reps for you!
Old 01-28-2012, 06:11 PM
swing4thefence swing4thefence is offline
swing4thefence is starting off with a positive reputation.
Can anybody tell me where to find that broken piece from Martin's first picture? I just can't tell from the photo. It's too close up.
Old 01-28-2012, 06:47 PM
AllaboutMPG's Avatar
AllaboutMPG AllaboutMPG is online now
AllaboutMPG is a name known to allAllaboutMPG is a name known to allAllaboutMPG is a name known to allAllaboutMPG is a name known to allAllaboutMPG is a name known to allAllaboutMPG is a name known to all
Don't even have heated seats but I love the write up. Always helps to have cartoons. Reps at ya for takin the time to share.
Old 06-09-2012, 09:12 AM
Quote:
That little square thing is in the middle of the seat at the back where the upper and lower part meet. You can kind of feel it through the material.
Warn Hubs install/Wheel bearing help MacLeody 1999 to 2016 Super Duty 7 03-21-2016 12:19 AM
Removal of Super Duty lighted mirror covers Yahiko 1999 to 2016 Super Duty 20 09-11-2014 04:19 AM
Help Finding Shoe Retracting Assist Spring Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 10 03-23-2014 08:28 PM
65 Fixer-Upper & Question about VIN Codo 1961 - 1966 F-100 & Larger F-Series Trucks 18 06-25-2012 12:09 AM
tilt column reassembly DestroyerOfWerldz 1997 - 2003 F150 1 07-06-2010 11:00 AM
Tags
03, 2004, 2006, dont, escape, expedition, f250, ford, heated, seats, sport, trac, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
