Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- Water Pump Reviews
Reviews and comparisons of top products
Is it time to replace my water pump? (pics)
on
You'll need to source a big wrench to remove the fan clutch; I've used a 15" adjustable wrench several times on mine by taking most of the fan bolts out and holding the pulley with a prybar while turning the big nut that hold the clutch on clockwise (lefthand thread, just like the shroud says) until it breaks loose. You could also just buy the right tool at the parts store.
Ford Tool#: T84T-6312-C
Autozone rents or lets people borrow tools, and may have one of these for your truck.
If it was an admission of self-pride for a well done repair, then I apologize. Good job. I took it as a slide on general shoddy work by mechanics, and being a refrigeration mechanic, I personally get tired of hearing those digs... Seems like there is always someone out there that can do a better job than a grease monkey.......again, if I took it the wrong way, then I apologize.
I'd wager that most of us here would go away shaking our heads (and some of us have) if we could spend a day in some of the shops in our cities.
But it's unfair to pick on just auto OR refrigeration mechanics, because every trade has its turds. The trick is to find one who isn't and cultivate a friendship with them.
I have no doubt, though, that you're the kind of refrigeration mechanic I'd want to have do my work.
If ya want my honest opinion, in this situation (what I did with my '84), I would put a pump, thermostat (since you are putting in a new pump), and a flex fan on, and get rid of the fan/clutch all together. I never have liked the clutch set-up, and when I put the new motor in my '91, it's going by-by as well. You are correct, the job isn't very hard. It can be time consuming, but then again take your time, so there are no leaks. Like I said, this is only my opinion, and should be treated as one.
A clutch fan will help you get a bit better mileage and will be less noisy at speed, and to convert over to the flex fan you'll have to install a water pump from an older model pickup, since the one for your truck has a threaded on boss for the fan clutch.
But with all respect to sparky, I can certainly understand why he'd suggest the swap. I just wouldn't do it personally, because I don't agree that it will be better. That's MY opinion, with heavy emphasis on opinion.
on
I disagree. FoMoCo put the clutch fan on for a reason; they wouldn't have spent a nickel more to build the truck than they had to.
A Flex fan is a downgrade to the cooling system.
A flex fan by design flexes the blades flat at high RPMs, reducing drag, but pulling in less air the faster it turns. This is detrimental at slow speeds climbing hills at higher RPMs.
A Clutch fan cools the same at slower RPMs as it does at higher RPMs, and does not flex flat the faster it goes. Not only does this save fuel, it cools better than a flex fan. A thermostatic Fan Clutch cools even more because as the temperature rises, the clutch engages more untill the fan is full on. Pulling the most air at RPMs. Something a flex fan cannot do.
This is why a clutch fan is a cooling upgrade and is an optional extra on these older trucks and cost you more money, and why the flex fan is standard.
I don't take my vehicles to other mechanics BECAUSE of the shoddy work I've witnessed being performed over the years. I can only recommend three mechanics in my city of 60K because of it. And I still do my own work, because I do a better job, period. I take my vehicles in only until I can learn to do the work myself. People dig at mechanics for a reason.
I would pay someone like Wyowanderer TWICE what a shop mechanic would charge to work on my truck, plus buy him lunch and beer afterwards. Why? Because it would be done correctly and I could see how it is done.
Also, flex fans make an awful buzzing noise when they spin. I hate them. I'd stick with OEM and replace the fan clutch.
Glad you still have the shroud. I got lucky and found one for mine that cured its hot running problems!
Another vote for fan clutch over flex fan, and I'd prefer yet to have an electric fan over a clutch fan. (Zero drag on the motor when cooling is not required, and a much cleaner engine bay)
If you were out in my area, I'd tell you to bring your truck by my place so we could power through the WP install.
I'm not a 300-6 expert, so I can't vouch for their timing chain, but it may be a good time to replace that as well. Any thoughts from the guys who know more?
#30
on
Some 300-6s had a plastic gear to make the engine quieter. So if you had one of the plastic gears, it might be prudent to change them to all metal.
But I have to agree, very seldom do those gears cause problems.
