Starting system wiring question........
Hello all, my internet challenged friend is having trouble with his van and I am trying to help him........ so I have a simple question for you: Vehicle: 1998 Ford van, looks heavy duty, two batteries, extended roof. Problem: Suddenly quit starting! As in fine one moment - nothing the next! What we know: There is NO continuity in the wire from the relay (under the hood, with the fuses) to the starter. He tapped into the starter wire about a foot from the starter and when power is applied the starter cranks. We checked the relay and it is definitely working and sending power down the line. So...... my question is - is there ANYTHING between the relay and the starter that could be disrupting power?? A fuse? A bad connecter? Or is this a solid wire all the way? I could not find an online schematic anywhere. Anyone know a link? Right now our solution is to run a new wire between the relay and the starter. Does anyone have a better idea?? Hope someone can help us out, he's a super nice guy and I would really like to get this fixed. cheers! c
Well, how he has been starting it is - he bared some wire on the starting wire (ahhhh, what's the more accurate name for it???) and attached a little "pig tail" which he then hits with 12 volts and it starts instantly. So from this, perhaps inaccurately, we concluded that the starter is fine and the problem lies in the wire between the relay and the starter. Unless there is something other than just wire between these two?
warren561
03-06-2019 04:33 PM
dieselzen
02-09-2011 01:24 AM
bermblaster41
1983 - 2012 Ranger & B-Series
10-15-2008 06:42 PM
MineralStang
06-10-2006 05:57 PM
judyms772
01-22-2006 11:39 PM
