Ignition problem
Ignition problem
I have a 1988 f-250 4wd. It has a 460. When I start the truck the key will not turn it back off. When I connect the battery cables the dash lights up like I had turned the key. The key doesn't need to be in it. I tried changing the ignition cylinder. And the new one was the same way. What do I need to check?
Take off the steering wheel. You need an ordinary bolt-grip puller. Then remove whatever screws you see and take off the collar and the turn signal switch. That should be enough to see if something is broken. I've never replaced this part myself though, so I'm not sure how much further you would need to disassemble.
Received 3,090 Likes
on
