1997 f150 4.6 overheating - Ford Truck Enthusiasts Forums
Old 07-01-2011, 05:53 PM
five.fold five.fold is offline
five.fold is starting off with a positive reputation.
Hi- only second time around posting here-I recently bought a 1997 F150 xcab lariat 4x4, 212k miles, 4.6 engine. radiator was bad, replaced it, replaced heater core(leaked), new thermostat, radiator(bottle)cap, water pump. At no particular time, reason, a/c on or off, it will build pressure and spew a/f out of cap(before new cap, blew upper hose off). This has happened 3 times now in the last 2 days, always on short trips. drove all afternoon yesterday, stop and go driving around town, 100 degree outside temps, with the a/c on, no problems at all. today, driving back from golf course, about a 5 minute drive, a/f spewing out of cap by the time i got to my driveway. Bad head gasket? No white smoke, no oil in a/f or a/f in oil. also, a/c coil cleaned out. plenty of air flow from rad fan.
Old 07-01-2011, 08:29 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Sounds like you might have air in the system.
Old 07-01-2011, 09:07 PM
what's the best way to purge it? wont it just purge itself as i drive?
Old 07-01-2011, 09:14 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is online now
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Sounds like a bad head gasket allowing compression to get into the cooling system. Start with a cold engine and put a pressure tester on then run the engine. If it starts building pressure before the tstat opens then the head gasket is bad.
Old 07-01-2011, 09:23 PM
thanks, 70, i give that a try tomorrow.
Old 07-02-2011, 02:44 PM
Ran the truck 15 minutes from cold start, only negligible amount of pressure, none at all for the first 4/5 minutes.Revved engine to 3500 several times while idling, no problems. just got back from taking it to lunch (a/c on), no overheat at all. I can, however still hear water/air gurgling thru the heater core.
Old 07-02-2011, 04:10 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Sounds like air then, you need to remove the degas cap and turn the engine on and let it run.
Old 07-02-2011, 07:26 PM
DEGAS CAP? If you are talking about the little valve in top of the t-stat housing, there isnt one on this truck. where else do i look?
Old 07-02-2011, 09:07 PM
The cap on the overflow, i.e. degas, bottle.
Old 07-02-2011, 10:13 PM
Oh. never heard it called a degas bottle before. I'll give that a shot.
Old 07-04-2011, 11:57 PM
didn't work. anyone have any other suggestions?
Old 07-05-2011, 08:41 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
I heard parking on a slight incline and then try to bleed the coolant system helps
Old 07-05-2011, 11:02 AM
Yeah, i pulled the truck up on ramps, it made sense to try that. No luck.
Have been running engine for the last 90 minutes, revving, a/c on and off, cap on for the last 30, not even a burp! (Drove it yesterday to a 4th celebration, spewed and overheated less than a mile from the house, cooled it down, drove on to picnic-nothing. Got in and started home, same thing happened, drove a mile or so, spew and etc., cooled down, drove rest of way home-no problems.) I hate to tear into it if it isnt a head gasket.
Old 07-05-2011, 02:39 PM
IS your T-stat sticking?
Old 07-05-2011, 04:56 PM
that is looking like my next step, although I just installed this one last monday!
Cooling Issue... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 61 06-02-2016 09:33 AM
1994 F-150 5.8L XLT Overheating hadam 1987 - 1996 F150 & Larger F-Series Trucks 19 01-04-2016 01:00 PM
1997 f150 extended cab v6 3 door a.c. Mike Parker New Member Introductions 3 11-07-2015 01:23 AM
Which radiator do I have ? sgtscrounge 1997 - 2003 F150 7 12-15-2010 06:49 PM
1997 f-150 4.6 4x4 A/C Comp Clutch saltydwg 1997 - 2003 F150 2 11-23-2010 08:20 AM
Tags
150, 1997, 46, 97, cylinder, engine, f150, ford, motor, overheat, overheated, overheating, overheats, thermostat, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
