1997 f150 4.6 overheating - Page 2 - Ford Truck Enthusiasts Forums
Old 07-06-2011, 11:41 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Take the cap off and just let it run until the thermostat opens(the upper rad hose will get hot). Make sure the coolant is to the full level then use this tool to check for a bad head gasket. ANY color change means there is a leak. I tap into the vac line on the fuel pressure regulator.
Old 07-06-2011, 04:06 PM
five.fold five.fold is offline
five.fold is starting off with a positive reputation.
thanks for the tip. will keep you posted.
Old 07-08-2011, 07:33 PM
Just tested with my new tester-3 times-ALL BLUE ALL THE TIME. Did notice the lower radiator hose collapsed (as well as the upper) while i was testing. Could it possibly be that the lower hose collapses the first time the t-stat opens because of the pump suction, causing my problem, then once the system has built up pressure from the heat, the lower stays open because of the pressure, hence no overheating till the engine is completely cooled off?
Old 07-08-2011, 07:37 PM
I drove this truck all day today. first thing this morning, gauge pegged. pulled over, turned off engine, waited 10 seconds or so, restarted, gauge needle fell like a rock, drove the rest of the day(app 30 miles around town, stop/start, here there), no problems whatsoever!
Old 08-01-2011, 07:25 AM
update-Installed a 180 t-stat, no problems of any kind since. live in midwest-kc area, 98 degree outside temps, runs like a sewing machine, good reading on gauge-about 1/3 of the way up.
Old 08-02-2011, 08:33 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is online now
enriched&beyound is starting off with a positive reputation.
Quote:
Could be....more likely, the radiator hoses are weak and & cutting off or restricting currulation when in colapsed state. they shouldn't colaps
also the 180* T stat, is bit low...and may upset the running parameters a bit...run rich on cold starts. this may not be a real issue until colder weather hits, as it with run rich longer due to colder outside temps.
Old 08-02-2011, 10:29 AM
enriched-Thanks for the input, think I'll live with the 180 till cold weather, its not that big of a deal to switch out t/stats. thanks to all for the input.see ya down the road! (I'll probably be in a CHEVY, though!)
Old 08-25-2012, 11:54 AM
LANKY LANKY is offline
LANKY is starting off with a positive reputation.
3/16ths hole in thermostat
Hey first time here, I had the same problem it started when I changed the thermostat. What I did to fix was took the thermostat back out and drilled a 3/16ths hole in the thermostat outer rim that lets the water flow thru and haven't had any problems since.
Cooling Issue... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 61 06-02-2016 09:33 AM
1994 F-150 5.8L XLT Overheating hadam 1987 - 1996 F150 & Larger F-Series Trucks 19 01-04-2016 01:00 PM
1997 f150 extended cab v6 3 door a.c. Mike Parker New Member Introductions 3 11-07-2015 01:23 AM
Which radiator do I have ? sgtscrounge 1997 - 2003 F150 7 12-15-2010 06:49 PM
1997 f-150 4.6 4x4 A/C Comp Clutch saltydwg 1997 - 2003 F150 2 11-23-2010 08:20 AM
Tags
150, 1997, 46, 97, cylinder, engine, f150, ford, motor, overheat, overheated, overheating, overheats, thermostat, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
