Dand 60 Rear hub nut size?
Old 07-01-2011, 04:16 AM
duke_boy's Avatar
duke_boy
duke_boy is offline
Hi. I've searched the forums for a while so here comes my question. I'm trying to remove the rear hubs on the dana 60 in this 1966 f250 2wd.
Anyone know what size socket to use?
I read in one post where a 2-3/8" was too big but that's the closest measurement I can come up with. I'm heading to the store to get one tomorrow....ur, I mean today.
Anyone know what the correct torque for the pinion nut is?
Also, I am just replacing the pinion and wheel seals. No other changes in the rearend over the factory setup.
Thanks!!
Old 07-01-2011, 07:30 AM
Blackwaterforge's Avatar
Blackwaterforge
Blackwaterforge is offline
Mine is 2 5/16
Old 07-01-2011, 07:41 AM
duke_boy's Avatar
duke_boy
duke_boy is offline
Thanks blackwaterforge. I'll give that a shot. I can't imagine my should be any different than what you have.
Old 07-01-2011, 07:58 AM
Blackwaterforge
Check and make sure your vent hose is open.
A clogged up vent hose(usually by mud dobbers) will blow your seals.
A regular 2 5/16 socket will not go into axle housing.
It will have to be an axle socket.
Bought mine off e-bay when I couldn't find one locally.
Spicer model 60 Pinion shaft nut torque to 250-270 per 1965 shop manual.
Old 07-02-2011, 12:18 AM
99hosss's Avatar
99hosss
99hosss is offline
hey partner , how much was your new pinion? and who sold it to you? I need to get my 4.56 up a bit
Old 07-02-2011, 06:17 AM
duke_boy's Avatar
duke_boy
duke_boy is offline
99hoss - I didn't actually buy a new pinion gear. I'm just replacing the pinion seal and putting a new nut on. I ordered my parts through Randys Ring and Pinion. They were super nice to talk to.
Also, my Dana 60 needed a 2-3/8" axle nut socket...fyi.
Old 07-02-2011, 11:24 PM
junkyardjeff's Avatar
junkyardjeff
junkyardjeff is offline
My 66 f250 had a different size nut then the 71 rear end that replaced it so I bought a set of sockets from the tool truck that comes to the shop,spent a little money and only used a couple of the sockets a couple times but will have them now when the need arises.
zrt600guy
06-06-2016 02:37 PM
jawdoc
09-30-2015 02:15 PM
jawdoc
1997-2006 Expedition & Navigator
09-30-2015 09:41 AM
mustangmatt
1999 to 2016 Super Duty
04-10-2014 09:44 AM
Supercab
03-27-2008 07:25 AM
Quick Reply: Dand 60 Rear hub nut size?
