Toyota power steering?
Old 07-02-2011, 07:22 AM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
Originally Posted by Moe Craig
Bonus Builts refer to 48-52 most of the time... Narrower frames then the 53+
"Monkey Face" = 48-50
1st pic (mine)
"Bucktooth", "Bad Teeth", or "Manure Spreader" = 51-52
2nd Pic (don't remembers who's this is)
Thats what I thought. Your truck is very cool. So it the second one. Hell they are all cool.
Old 07-02-2011, 11:18 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Thanks for the complement about mine. And I agree, all old trucks are cool... My favorites are 48-50!
Old 07-05-2011, 07:53 PM
special 55's Avatar
special 55
special 55 is offline
I think that Damifiknow, from his avatar, has a bonus build like my monkey face, I haven't jound a toyota mounting bracket... Has anyone found one yet?
I used the kit from Clasic Performance Parts on my 52 F1. It is the same as some of the others out there. The bracket is for a 53 and newer but it fit the F1 with very minimal alterations. I just opened up the pitman shaft hole which you do on the 53 and up anyway, used the lower hole in the stock location, elongated the front upper mounting hole and drilled a new hole for the upper rear.
I intent to get some pics up soon but don't have any right now. The swap was pretty easy but I am also working on a bare frame so gaining access was not an issue for me.
I am very happy with the quality of the CPP bracket and pitman arm and would recomend it if someone asked.
Good luck with your upgrade,
Rich
Old 07-06-2011, 08:53 AM
Damifiknow's Avatar
Damifiknow
What did you do with the pump? I have a flatty and I've only seen one kit for a flatty pump for $450.
Old 07-06-2011, 09:31 AM
special 55's Avatar
special 55
Sorry I should have mentioned it's a 302/C6 combo so i just used a standard Ford P/S pump with aftermarket brackets and pulley.
Haven't gotten to the hoses yet so I'll be following along to see how you do
Rich
Old 07-07-2011, 02:22 PM
1949 School Bus's Avatar
1949 School Bus
1949 School Bus is offline
Has anyone tried to put the Toyota steering box on 1948 F-5 truck?
Old 07-07-2011, 05:30 PM
1949 School Bus
has anyone tried to install the Toyota steering pump on a 1949 F-5?
Old 07-28-2011, 10:30 AM
special 55's Avatar
special 55
Rich
Here are a couple pics of the F1 install using the F100 bracket.
The bolt circled in green being original. The one circled in yellow drilled slightly forward of the original. The one in red is all new drilled for bracket.
Here you can see the gear mounted in it's final location. Just enough clearance between the gear and the block hugger headers.
Hope that helps out some of you looking to do this on your F1 without fabricating your own bracket.
Rich
Old 07-28-2011, 12:52 PM
Moe Craig's Avatar
Moe Craig
Rich
Thanks Rich,
What is the yellow bolt screwed into? Do you have any pics of the Box and Mounting plate prior to mounting it to the frame? I have to buy one since I don't have the use of a shop to make one myself.
Old 07-28-2011, 12:55 PM
special 55's Avatar
special 55
The bracket is side drilled and threaded. All three bolts thread into the side of the bracket through the frame. The Gear needs to be mounted to the bracket prior to the frame.
Sorry, no pics of bracket before but CPP has one on their website.
Old 07-28-2011, 01:01 PM
eman92082's Avatar
eman92082
eman92082 is offline
Another alternative is to make your own. I have a fairly detailed section in my gallery regarding this. It worked out pretty well.
Cheers.
Fomoko1
09-19-2016 09:04 AM
IHCubCadet
General Automotive Discussion
07-23-2016 01:42 PM
dj lpm
2015 + Expedition & Navigator
04-15-2016 12:31 AM
wawii
01-05-2016 10:26 AM
f1501987
31
01-13-2013 01:16 PM
Quick Reply: Toyota power steering?
