1999 F150 4.6L - Injector questions - Ford Truck Enthusiasts Forums
Old 06-30-2011, 03:22 PM
trailor trailor is offline
trailor is starting off with a positive reputation.
Well first and foremost I need to know what kind of injectors come in a stock 1999 4.6L F150 (keep in mind, this model doesn't have COP's, whether or not that makes a difference). By what kind, I mean are they EV1 or EV6?? I have searched and cannot get a definite answer. Also, just wanted to double check, they are 19lbs./hr injectors, correct??
I probably have some further questions, but I am at work right now so my time is limited, and getting this answer alone will get me started on my repair process. Thanks in advance for your responses!!
Old 07-01-2011, 02:40 PM
BUMP.. anyone?? need to get the parts ordered soon...
Old 07-01-2011, 03:22 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
I don't know what your truck has now but they are not critical for injectors as long as the plug is correct.
Look at the ROCK AUTO site for injectors for F150 4.6 and you will see a whole bunch of alterate Ford part numbers that can be used.
Look on yours for PN and color.
Just curious what is the reason for changing them other than general maintaince?
Good luck.
Old 07-02-2011, 09:15 PM
Good luck.
Not trying to replace, trying to thoroughly clean. And to do that, I need a parts kit that supplies new filters and o-rings, as well as a test bracket. In order to buy this kit, I first need to know if I have EV1 or EV6 because the filters and o-rings, as well as the test bracket, are different sizes.
Old 07-04-2011, 01:15 AM
keyul's Avatar
keyul keyul is offline
keyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to allkeyul is a name known to all
You may be able to visually match it, take a look at the image below under body style, or go to:
Ford Racing Performance Parts - [2010 Catalog]
And at the bottom type in page 222
If that dont work, call your local parts/service department and they should be able to tell you:
Old 07-04-2011, 03:05 PM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
Send `em to a local injector shop !
I send all the injectors that I want cleaned to my local injector shop... they not only do diesel but as well as gas injectors ...they clean them with an alkaline solution while flow testing them at the same time on their bench machine... then they put new top hat filters and o-rings before they send them back to me... I get charged between 25-35 dollars per injector
Old 07-05-2011, 10:19 AM
Quote:
that does seem like a tempting idea, but the kit i'm looking at online with all the new filters, o-rings, and test bracket, costs ~$25, and the UV jewelry cleaner costs ~$30 at harbor frieght, and a bottle of concentrated fuel injector cleaner costs ~$2. So for a total of ~$60 i find that to be a bit of a cheaper DIY alternative.
thanks for the responses guys. fortunately, after doing some other work to the truck first, i was able to find that a faulty injector was not causing my problem, but i will keep this thread tagged in case i ever need to do that job. thanks!
4.9 PCV valve differences moonley 1987 - 1996 F150 & Larger F-Series Trucks 0 12-17-2016 04:01 PM
EV1 vs EV6 Injectors RZAR Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 08-11-2015 10:36 PM
Injectors RZAR 1987 - 1996 F150 & Larger F-Series Trucks 0 08-10-2015 11:58 AM
EV1 Injector Revamp and Install Evan_P 1987 - 1996 F150 & Larger F-Series Trucks 2 06-07-2013 09:10 PM
EV6 Injector Swap dcciie251 1987 - 1996 F150 & Larger F-Series Trucks 2 02-25-2011 02:16 PM
Tags
1997, 1999, 2000, 46, check, clean, f150, ford, fuel, injection, injector, injectors, liter, ohme, range, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
