AC Compressor Mounting Woes, belts, etc. *pics* - Ford Truck Enthusiasts Forums
Old 06-30-2011, 02:31 PM
KrenzyRyan's Avatar
KrenzyRyan KrenzyRyan is offline
KrenzyRyan is starting off with a positive reputation.
So, still working on putting AC in my new project. Found a mount at the junkyard for the style AC compressor designated for this truck. Bought a new compressor, and nothing seems to align just right. The pulleys just don't match up!
Take a look, let me know what you think,
Old 06-30-2011, 03:00 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Maybe use fender washers to space the bracket back.
Old 06-30-2011, 03:27 PM
KrenzyRyan's Avatar
Cant, it mounts on the front of the cover. I just dont understand how it just isnt a direct fit...
Old 06-30-2011, 03:28 PM
KrenzyRyan's Avatar
Double post..
Old 06-30-2011, 03:36 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Am I seeing the pics right? There appears to be an unused groove between the alt and PS belts. If so, I bet either the pump gets spaced back to use that middle groove, or has a different pully for the A/C to be installed.
Also, if you live where it's hot enough to go thru the effort to add A/C, you're going to want to upgrade to the factory A/C radiator. That tiny non-A/C radiator isn't going to be capable of keeping the engine cool, especially in slow speed traffic.
Old 06-30-2011, 03:39 PM
Archion's Avatar
Cant see the pics that well on my phone. Photo sharing sites are blocked at work.
Old 06-30-2011, 03:49 PM
The above diagram shows the PS belt in the middle groove, and the A/C belt out front. Something isn't right with the PS belt location. Granted, my truck has the PS belt out front, but my dealer added A/C has the compressor sitting directly above the alt, and dual belts that go around the crank, alt, A/C and WP. The air pump was driven by a narrow belt that goes from WP to AP only.
Either your PS pump needs shimmed back, or the pulley has to be changed to free up that groove for the A/C belt.
Old 06-30-2011, 04:12 PM
Archion's Avatar
The WP and crank pulley should be different on ac vehicles IIRC.
Old 06-30-2011, 05:00 PM
f100jim's Avatar
f100jim f100jim is offline
f100jim is gaining momentum as a positive member of FTE.
My '82 F100 has dealer installed air. The A/C pulley has two grooves, and the belt goes in the groove closest to the compressor. My power steering pump has spacers (about 5/8" thick) between the PS pump and bracket so it uses a groove on the crank pulley further back than it would without the dealer air.
Old 06-30-2011, 06:48 PM
Kylet8020 Kylet8020 is offline
Kylet8020 is starting off with a positive reputation.
omg i did this my self once i was puttin ac on my 300 6 check your ps bracket and make sure its spaced back if i remember right the ac braket bolted to the ps brackets i used the wrong spacer..... there is a spacer that is behind the ps bracket i think thats where u need to look god its been awhile hope this helps ya
Old 06-30-2011, 10:04 PM
KrenzyRyan's Avatar
Everyone, thanks for all the input!
Quote:
Jim, do you have any pics of your setup?
Old 06-30-2011, 10:14 PM
KrenzyRyan's Avatar
I think I just found what compressor was originally on this truck. Does anyone know what this compressor cross references to in terms of stock applications?
63 64 65 66 67 68 FORD A C COMPRESSOR CONVERSION | eBay
Old 06-30-2011, 10:29 PM
fordnut forever's Avatar
fordnut forever fordnut forever is offline
fordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to allfordnut forever is a name known to all
here's a pic off my 83 hope it helps you,
Old 06-30-2011, 10:39 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
Quote:
Randy yours is the same compressor as mine they call it an FS6, you have dealer installed air, asfor the original poster, it looks like you need another pulley on the crank.
Old 06-30-2011, 10:42 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Which is apparently factory-installed and looks like the image below.
Ryan - what year is your truck again? The parts catalog shows myriad factory installations, but isn't yours dealer-added?
Intro and Build Log: The Yellowfin Tow Pig and Hurricane Response Vehicle AGP Excursion - King of SUVs 107 06-07-2016 12:47 PM
Pic Request - Post Your Engine Bay! KrenzyRyan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 62 12-20-2013 11:04 PM
My New Project - 1980 F100 - Pics KrenzyRyan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 09-21-2013 06:47 PM
Another leveling kit/35" tire install thread 2000silverbullet 1999 to 2016 Super Duty 33 09-15-2012 03:26 AM
Trying to fix AC Wires, What is this thing? *Pics* KrenzyRyan Cooling, Heating, Ventilation & A/C 8 07-04-2011 12:48 AM
Tags
05, 390, 4346, ac, air, auto, bracket, compressor, condenser, conditioning, corvette, ford, freestile, mount, mounting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
