Pre-Lube oil pump - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Pre-Lube oil pump
Old 06-30-2011, 12:01 PM
ahuggins6 ahuggins6 is offline
ahuggins6 is starting off with a positive reputation.
Pre-Lube oil pump
Several years ago, I bought a prelubing oil pump system for my F-150. I kept it when I sold the truck and now would love to put it on my super duty 6.0. The questions I have are:
1) Is it possible to get the oil pan off the engine without jacking the engine up? I need to weld a 3/8" pipe bung on the side of the oil pan to pull oil for the preluber. Has anyone had to drop the oil pan for some reason?
2) Where is the oil pressure sending unit/ sensor? I need a place to feed the pressured oil back into the engine, probably using a T fitting. Or is there a plug in the side of the block I can pull and put the feed into?
This system came with all the pieces to fit the F-150, but I'll be fitting it to this next truck as I go.
Need better pump for prelube system sunbelt57 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-26-2016 07:14 PM
Engine oil pre-lube kits bignorthford 1997 - 2003 F150 3 02-27-2008 10:25 AM
Dirty Side of Oil Filter? barnbridge 6.0L Power Stroke Diesel 13 12-02-2006 06:30 PM
Homemade Pre/Post Luber Questions nlemerise 1999 - 2003 7.3L Power Stroke Diesel 26 07-27-2006 04:34 PM
390 pre-lube? DutchmanAZ FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 05-06-2002 04:20 PM
Tags
2008, 351, 352, escape, ford, gm, lube, oil, oiling, pre, prelube, preoiler, pressure, pump, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
