Brake Line Diagram
If the master is under the floor, the easiest way to do it is to run the felxible hoses to the frame from each wheel. Then run the hard lines from the brake hoses together to a 'Tee' fitting near the driver's side, you may or may not need to put a 2 lb residual valve in the line, then run a line connecting the RV (if used) to the front reservoir of the master. Make sure the flex lines don't rub or contact anything.
Hobdy
36
04-22-2019 04:44 PM
tigertail222
02-06-2013 09:37 PM
