Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
09 Escape Acceleration Hesitation....
Old 06-30-2011, 08:50 AM
GRNMSTR's Avatar
GRNMSTR
GRNMSTR is offline
I have a 09 Escape Limited with the 3.0L v6 and it only has 38K miles on it. The problem that I am having is that when accelerating either from a stop or when moving down the road the engine hesitates or just looses power. I have actually had the engine quit a few times when pulling onto a road admidst the intersection. I took it to the Ford Dealer and they said they drove it and did not feel the problem but they did re-flash the PCM. Needless to say it is still has the problem.
I have a 04 5.4L F150 that has a similar issue around 36K miles and it turned out being the Spark Plugs.
Does anyone have any suggestions as to what could be causing this? I have changed fuel, ran octane boost and injector cleaner in hopes of correcting this problem with out any success.
Any information that you can share is greatly appreciated.
Old 06-30-2011, 05:26 PM
wptski's Avatar
wptski
wptski is offline
I almost got T-boned making a left hand turn because of a hesitation like you describe. Got the same song&dance from the dealer, called Ford CS, back&forth and finally a PCM reflash was done which fixed my problem. I have heard of one that was fixed by replacing the DBW unit on the throttle body.
I can't understand why dealers don't look at the manuals they have as they mention drivability problems that don't throw codes and are intermittent. Yet they say that it passed a test drive and shows no codes!
Old 07-01-2011, 12:17 PM
BlueOvalDude's Avatar
BlueOvalDude
BlueOvalDude is offline
GRNMSTR,
Have you tried replacing the ignition coil assembly? I had a similar issue with hesitation upon acceleration with my old Escape and the culprit turned out to be the ignition coil. The dealer tried to charge me $125 for the part plus labour but I just ended buying the same OEM part for $65 at Ford Parts - Genuine OEM Ford Auto Parts at FordPartsGiant and did the job myself. It took me under an hour to perform and I concede that I'm not that proficient of a mechanic
Another possible cause of this acceleration hesitation could be from a dirty Idle Air Control Valve. You can clean the unit but if that doesn't resolve the issue then the replacement job takes a scant 20 minutes to do. Here's a concise write-up on how to replace the IACV on an Escape:
1) Locate the idle air control valve on your Escape. On 3.0L V-6 engines, the valve is located directly on top of the intake manifold, in the center of the engine bay. It is directly to the left of the air intake assembly. On 2.3L four-cylinder engines, it is mounted on the side of the intake manifold, behind a plastic cover.
2) Unhook the negative battery cable.
3) Remove the three screws from the plastic cover if your Escape has the four-cylinder engine. Move the cover out of the way.
4) Unhook the electrical connection attached to the idle air control valve by pressing the tab and pulling out.
5) Remove the two screws mounting the idle air control valve. Take the valve and its gasket off. The gasket can't be reused.
6) Mount the new idle air control valve and gasket. Tighten the screws and reattach the electrical connection.
7) Replace the plastic cover (2.3L four-cylinder models). Reconnect the negative battery cable.
Regardless of what happens to be the cause of your engine's stumbling, I hope that you get to the bottom of it soon
Old 07-01-2011, 03:42 PM
tomw's Avatar
tomw
tomw is offline
A contaminated or dirty MAF can cause hesitation. It can also cause lean codes to be thrown ...
tom
Old 07-01-2011, 05:55 PM
wptski's Avatar
wptski
wptski is offline
They use a MAP not a MAF and I don't believe the '09s use a IAC either.
Old 12-10-2012, 10:21 AM
Jreodica's Avatar
Jreodica
Jreodica is offline
My '08 Escape AWD hesitates as I accelerate through 50mph to 70mph... The hesitation stops completely when I hit approx 75mph... Seems I have to speed up to avoid the hesitations.
Normal street driving is mostly fine. It happens at highway speeds.
Anyone have any thoughts as to what it may be?
Old 12-10-2012, 11:36 AM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
Jreodica coil on plug pack starting to go.Is my guess.You may have a pending code so your CEL wont by lit.
grande351
3.0L V6
11-02-2019 08:17 AM
20powerstroke02
07-25-2016 07:23 PM
disneyd
30
02-06-2012 11:30 AM
hokie86
1997-2006 Expedition & Navigator
15
07-07-2009 12:16 PM
ranger_ron
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-23-2006 07:30 PM
Quick Reply: 09 Escape Acceleration Hesitation....
