Engine ticking under load - Ford Truck Enthusiasts Forums
Old 06-30-2011, 12:12 AM
rollin35s rollin35s is offline
rollin35s is starting off with a positive reputation.
I have a 2008 F150 5.4L and after pulling my trailer I have a really noticeable ticking coming from the engine. When you start it up it is really noticeable for a few seconds then disappears and sounds perfect, once you start to put the engine under load when driving it is really loud coming from the passenger side. Any ideas. ready to scream.
Old 06-30-2011, 08:20 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Could be the cam phaser tick. Does it sound like a diesel?
Could also be a bad injector, as they make an audible tick also.
Are you sure it's not the metallic "ping" which is predetonation?
Old 06-30-2011, 09:22 PM
j_blueridge j_blueridge is offline
j_blueridge is starting off with a positive reputation.
I get what may be the same sound when I start the engine. It too goes away after a short time. Reminds me of my (some day to be reborn) '68 MGB.
In that car the poor design ensured that oil drained away from the rocker arms, pushrods and tappets (lifters) when the car was turned off. When you start the car they run with little oil so they sound loud until the oil gets pushed to them from below.
Unlikely, but a hole in the exhaust manifold? That makesa tapping/ticking sound as one cylinder shoots its exhaust out. I was driving a school's "mini-bus" with a soccer team and I heard a bad sound like that. After 5 minutes a spark plug blew itself out of the head; found it hanging by its wire.
Maybe try an engine oil additive or an oil change. Predetonation or pre-ignition can be from funky fuel or the ignition being off. Looking at spark plugs can tell you if the fuel is burning correctly. There should be a small amount of a light grey or brown deposit on them. Sometimes they have black crud built up or they look glazed. That would mean something is wrong.
Old 07-01-2011, 06:29 AM
dos0711's Avatar
dos0711 dos0711 is offline
dos0711 is starting off with a positive reputation.
Sounds like an exhaust leak to me
ticking engine strat875 Modular V8 (4.6L, 5.4L) 2 10-15-2016 03:35 PM
2000 f-150 Ticking sound. Engine or Transmission ?? PSDChick 3.8 & 4.2L V6 14 09-27-2015 07:36 PM
98 F150 4.6 engine tick 4fords 1997 - 2003 F150 8 06-26-2012 04:43 PM
help identify ticking sound- 04 explorer 4.0 anello1960 Explorer, Sport Trac, Mountaineer & Aviator 5 05-17-2010 02:55 PM
1997 F150 4.6L - Engine tick - new headers, tightened plugs, etc. CJN 1997 - 2003 F150 24 05-10-2010 10:03 PM
Tags
150, 1996, 2008, 46, 54, 54l, coming, engine, f150, f250, ford, gas, load, motor, ticking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
