Long crank and won't start when hot
I looked in the tech folder and got some ideas. So I'm wondering if it's the ICP/IPR sensors or a leak in the oil system.
Truck starts fine cold.
After running and getting to temp it won't restart. Just cranks but won't fire up.
Checked starter, batteries, FICM, just changed oil last weekend (15w40 and ford filter)
When i let it sit for about 30-45 min it will start up again. When hot idling the IPR is 22.27 %
ICP is 0.9 V - but it bounces a little from 0.85v-1.0v but generally sits on 0.9v
When I crank the motor the low pressure oil gauge on the dash doesn't move. I never really paid attention to it before this so not sure if it should. Also, AE showed ICP at 0.2 and 0.6V when cranking hot and 0.9-1.1 cranking cold.
The desired ICP and actual ICP seem to play tag. THe desired in the lead and the actual following shortly behind it. At idle or coasting they are pretty much the same.
Does this help narrow it down to a leak in the oil system (dummy plugs or something) or if it's just the IPR or bad ICP sensor?
I appreciate some techs advice. I need a shoulder to cry on.
Im with texans that IPR numbers you posted looked fine to me
heres what ya had
now the way I understand it if it did have a leak in the system IPR% would be way higher all the time to make up pressure for the leak like IPR35% or MORE at hot idel
heres the value
from left to right koeo,low rpm, high rpm, operating range before dtc
IPR # 14.84 24 40.60 0 - 50 PERCENT Injection Pressure Regulator
at low idel your only off 1.73% thats nothing I would expect it to be higher if ya had a leak
have you tried to unplug the ICP sensor when you have a no start condition and see if it will start
since you just had work done to the moter check all wire harness connections
heres what ya had
heres the value
