You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The one and only beef I have so far with my 6.2 is the throttle response. Just like my old V10 was with the electronic throttle programing. It feels mushy and not very responsive especially at low rpm. With my V10 I put a programmer on it which picked it right up. The programmer I used made the shifts way too firm for my taste though and it hammered into every gear. I had a great chat with Mike from 5 Star today and he knows what I am after and I feel he has the tunes I am looking for. I opted for the 87 performance/towing tune along with the 91 performance tune. For the third one I picked the standard 87 tune which more or less just improves the throttle response. I will be using the standard and towing tunes mainly as I am not looking for speed, just a change in how it feels.
__________________ 2012 Ram 3500 Laramie DRW
gone but not forgotten...2011 F350 CC SB Lariat 6.2 4WD 4.30's
I miss my 2000 V10's throttle response at times but generally the '11's isn't too bad. I just hate when I floor it and the truck waits a bit to think it out. My '00 just went.
I need to talk to my dealer about programmers and get their thoughts on it... I'd really like to get one.
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
I have read that stock mapping will allow the throttle bodies to open to 30% only, regardless of pedal position until you are close to 4k rpm, and even then it won't open to 100%. The tuner I have solved this and it is much more responsive from a stand still now (thanks 5 star).
Hi BOSS
Your correct
this is typical max allowed throttle opening angle on any 6.2
That's so they can easily change the mapping next year and come up with higher numbers to beat the competition Just kidding, but it does hold some truth...
The one thing about Mike is, he's usually very receptive to modifying the tune to suit your needs. If you get a tune from him, and you want something changed, email him, he'll email back the modified tune, and you can test it out.
Usually, I say... because he might be on vacation at the time you ask
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. Ž
That is what I am doing now. Back to work tomorrow though.
On a different note what temp do your trannys run at? Mine seems to stay up between 195 and 200 empty on the highway. Seems a bit high to me. I checked the fluid and it is towards the bottom part of the hash marks but not below.
Seriously?!?!?! (good to know but frustrating nonetheless. left a vm for my service guy, we'll see what their thoughts are on my warranty if i buy one!)
__________________
Matt
I have been looking and thinking about getting one too. But have been waiting to see if anyone has tried it yet.
Wondering will this fix the shifting problems too? Or is the trans flash required from the dealer?
I think I would go with the same one's you choose Super08. Those seemed to be what I was looking for, not really wanting to get the 91, but you do get 3 tunes.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
Are there any coupon codes we can use? Also when ordering online, where do you put which tunes you want?
__________________
Kevin
The tunes are in the section where you fill out the information on your truck. Go to the online store section and select 6.2. Once you are in there select the X3 tuner and there will be a large yellow highlighted area with a link to take you to the form.
I did my first oil change today. I always like to do early ones on a new engine to flush out the garbage. What a breeze to do after working on the 6.0 and the 6.4 for the last four and a half years. Topped off the tranny while I was at it, it took roughly 1/2 quart and now the oil level about 3/16" from the top of the hash marks when hot. There are no leaks to be seen so I am guessing it was not topped off at the factory. As for the oil changes, I can't believe they recommend something like 8000 miles between oil changes. The most I will let it go will be 5000. Even my diesels were getting changed every 5000 miles. I did this one at 1600 miles and I will do the next one when it hits 5000 and then every 5000 after that.
While I was underneath I was impressed with the mandrel bends in the exhaust pipes and all the insulation that is now under the cab and on the firewall. No wonder why it is so quiet.
