Smog pump holes
Old 09-03-2012, 01:33 PM
FordYoungGun35's Avatar
FordYoungGun35
FordYoungGun35 is offline
Smog pump holes
Okay removing the smog pump today of the 96 5.0.. I'm just putting a smaller belt on but I've read around and once you remove the pump and the charcoal filter by the battery what are the holes people talk about plugging, can someone give me a step by step walk through on removing it
Old 09-03-2012, 07:27 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
The charcoal filter has nothing to do with the smog pump/AIR system. That is for the fuel tank vapors. The holes you are referring to are in the back of each cylinder head. There is an external cross-over tube that connects them together with a check valve on top of it.
This assembly looks something like this:
Once you remove the cross-over tube/check valve you need to plug them with something like this:
courtesy of RJM Injection Technologies.
Old 09-03-2012, 08:30 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
The plugs are simply a 5/8" bolt 3/4" long.
In the pic above the shiney tube that goes to both heads. You can see the blok a the end with the bolt on the left side of the pic. Well if you remove the bolt on Both sides under the little block is the hole that the 5/8" bolt fits into.
I believe it's 5/8" might be 3/4" tho... Either way 2 bolts are cheap lol
Old 09-03-2012, 09:22 PM
FordYoungGun35
Any problems if I don't plug
The holes?
Old 09-03-2012, 09:31 PM
danr1's Avatar
danr1
danr1 is offline
The holes?
Bad exhaust leak if don't block em off.
Old 09-03-2012, 09:38 PM
Midnite1987
What he said^
The exhaust would be directed directly at the fire wall causing it to got very warm possibly causing issues and it would be loud.
Old 09-04-2012, 12:31 AM
FordYoungGun35
Am I forgetting something? Okay if your faceing the engine and on the passenger side the actual smog pump is the part of the belt route correct? And off the back of it is the metal tube with the black bulb and it's goes towards the back of the motor.. And behind the battery is the charcoal filter then behind that is either the soup can deal or the black plastic vacuum box.. Am I right with what the stuff is?
Old 09-04-2012, 02:51 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
Charcoal filter is mounted down on the frame rail next to the battery. LEAVE it there. Why exactly are you removing the smog equipment off your truck?
Old 09-04-2012, 07:02 AM
FordYoungGun35
The black can behind the battery that had a tube running off the smog pump is gone, and the vacuum box behind that that had two vacuum hoses connected to is gone and the vacuum hoses are plugged
And my cats are gutted, so the pump isn't really serving a purpose, plus I'm getting ready to rebuod the motor
Old 09-04-2012, 08:00 AM
Midnite1987
Seems to me it's a good idea to keep the vacuum can (soup can) its like having a tank for an air compressor...gives a constant vacuum
Old 09-04-2012, 10:04 AM
FordYoungGun35
Well the vacuum is on there now... But the charcoal filter is gone
Old 09-04-2012, 11:26 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
So now you get to smell the vapors from the fuel tanks............
Old 09-06-2012, 01:02 PM
cdrich07's Avatar
cdrich07
cdrich07 is offline
You can plug the hole on the manifold or you can get fancy with one of these. I ordered the wrong size so I have one in my tool box. They come with very good gaskets, metal center with fabric on each side.
RJM Injection Tech — EGR Eliminators
Rick94110
24
11-12-2016 03:27 PM
Clem's Cousin
12-16-2013 06:53 AM
86bullnose95
03-31-2013 04:51 PM
masseysbronco
11-09-2011 05:26 PM
Dustin_86
12-07-2007 09:57 AM
Quick Reply: Smog pump holes
