Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 06-29-2011, 11:57 AM
AndeyHall's Avatar
AndeyHall AndeyHall is offline
Garage is empty, add now
AndeyHall is starting off with a positive reputation.
Insight - VGT Duty Cycle %???
On my Edge Insight CTS, I updated it the other day and now it will monitor "Variable Geometry Turbo Charger Duty Cycle %". When I wasn't having issues with my truck, it would stay right at 85% at idle and at 0 throttle, and then when driving, depending on pedal position it would go down as low as the high 60s during normal driving. I never tested to see where it would go getting on it or at WOT. But here lately my truck has been having some MAF sensor issues and when I first crank my truck up in the morning it will start at about 78% and slowly creep up until it stops at 85%, and then it will drop like a rock with the least bit of throttle. Then once I drive it a few hundred yards it will stay at about 50-something percent with no throttle, and when I press the throttle it will drop down to 15%. After about a mile it won't budge off of 15% no matter where the throttle is or what gear the truck is in.
So can someone explain to me what a high percentage would mean and what a low percentage would mean?
__________________
03 6.0L F250 Lariat FX4 Crew Cab
SCT X3 w/ GearHead Tunes; Liberator EGR Delete; 4" Strait Pipe from the the cat back (muffler & cat delete); High Idle Mod; Tank Harpoon; Fog Light Mod; King Ranch side steps w/ lights
  #2 (permalink)
Old 06-29-2011, 02:13 PM
exiled's Avatar
exiled exiled is offline
exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.
Andy, I'm studing about vgt duty cycles. What I've found thus far is. Vgtdc should be 85% at wot, 43% at idel, 0 at koeo. I don't know if I understand this part so bare w/ me and if it wrong please somebody correct me. If vgtdc is measured by volts you actually have 0-100% dc and that would be wot and somewhere around 28psi I can't remember the volts but 100% or 85% if using a percentage. The thing about this though there is no feed to the pcm that actually tells it what position the vanes are in. I can't figure out how the dc is measured and what it actual means to us monitoring it. It appears just as useless as engine load, m.a.p, and intake temp along w/ a few others.
I forgot to mention that I see the same results that you do. At wot I'm seeing 4?% @ 20-22 psi boost. Maybe you'll have to get it to 28 psi to get 85% dc.
  #3 (permalink)
Old 06-29-2011, 04:18 PM
AndeyHall's Avatar
See I'm trying to figure out if I may have a bad VGT solenoid or if the issues I'm having with my MAF sensor is causing this...but here's what mine is doing:
When I first crank the truck up, it's at 85%. Then I press the throttle as I normally would taking off out of the driveway and it drops straight to 36.5%. Then I let off the throttle to coast a little ways and the highest it will go is 48.4%. Then I press the throttle again and it drops to 15%. Then I let off again to coast and the highest it will go is 34.1%. Then I press the throttle again and it drops to 15% again and won't budge from there. But no matter what percentage it reads, my truck has 0 power, it sounds totally different from the time I start it up, and every bit of boost it builts gets "farted" out of the air box as soon as I let off the throttle.
Needless to say this truck is quickly starting to **** me off in a big way.
__________________
  #4 (permalink)
Old 06-29-2011, 05:50 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
2003 Ford F-350
BLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud ofBLADE35 has much to be proud of
the vgt duty cycle has a high duty cycle at idel and a low duty cycle at high boost when the veins are pushed out
heres the operating value
VGTDC # 0 73 43 0 - 100 PERCENT Turbo Duty Cycle
this is from koeo =0%-low idel[628rpm] =73%-high idel[2500rpm] =43%
the vgt silinoid controls the turbo veins this is how I can kinda tell what position veins are at
__________________
Benny
2003 6.0, 4X4 srw, short box, born on 3/28/03 Moog ball joints,DC POWER 190A ALT Duralast Goldtop batterys 10/7/2012,RECON LED SMOKE MIRROR LENS,4 inch turbo back magnaflo exhaust,no kitty, 6 in. lift, BFG 315/75r16, python remote start alarm,pioneer system2 12''subs 1600watt amps ,scangaugeII,coolant filter, blue fuel pres spring, Fresh oil cooler 6/1/11 Final Charge Cat EC-1 rated Silicate Free ELC coolant, Sinister Full egr deleate, ROTELLA T-6 5w-40syn,updatedHPO screen,updated oil filter stand pipe
  #5 (permalink)
Old 06-29-2011, 05:57 PM
AndeyHall's Avatar
Ok, so since you know about my other issues, do you think they are causing my screwy VGT duty cycles or do you think I should try out a different VGT solenoid?
__________________
  #6 (permalink)
Old 06-29-2011, 06:28 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant futurecheezit has a brilliant future
you have 2 options....
do the old school boost test this should give you an idea if the vgt is working.
or take it back to Bill H.
__________________
Former Ford Senior master tech, gas and diesel.1992-2012
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned, 91 gallon RDS fuel tank.
  #7 (permalink)
Old 06-29-2011, 06:36 PM
2006lariat's Avatar
2006lariat 2006lariat is online now
Happy Day's
2006 Ford F-250
2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation
I have been reading all of the problems with this truck, Is Bill H. who is doing the work 4 real?
__________________
Adam
2006 F-250 PSD, TorqShift, Leveling Kit, Toyo MT's, Rancho 7000MT shock's, Rancho Dual steering Stab's, Swamps 58vlt FICM, 4" MBRP Turbo back exhaust (with muffler).
  #8 (permalink)
Old 06-29-2011, 06:57 PM
AndeyHall's Avatar
Quote:
Haha no! But what are these tests cheezit?
  #9 (permalink)
Old 06-29-2011, 06:59 PM
AndeyHall's Avatar
I'll try anything before I have to take it to any of these Bill H wanna-be's I live around.
  #10 (permalink)
Old 06-29-2011, 07:01 PM
cheezit's Avatar
active command vgt to 85%, egrdc# to 0 and rpm to 1200. moniter mgp.
should see 1.75+mgp but depeneding on eot.
next work egr and vgt one at a time, look and listen fir a change.
__________________
  #11 (permalink)
Old 06-29-2011, 07:02 PM
2006lariat's Avatar
Happy Day's
2006 Ford F-250
Quote:
Sound's as though Bill H woulda been a better option than who you've been dealing with! lol I am just saying, you have alot of problem's with your current mechanic's!
__________________
Adam
  #12 (permalink)
Old 06-30-2011, 12:30 AM
exiled's Avatar
Aight I had it reversed? Will you define a vgt dc?
  #13 (permalink)
Old 06-30-2011, 04:54 PM
BLADE35's Avatar
2003 Ford F-350
shure
Click the image to open in full size.
__________________
Benny
  #14 (permalink)
Old 07-01-2011, 02:05 PM
U235a4 U235a4 is offline
U235a4 is starting off with a positive reputation.
it's funny to see this post because I posted problem close to this on a another board. I wasn't even thinking the MAF sensor I was leaning towards the EBP or VGT.
  #15 (permalink)
Old 07-01-2011, 02:40 PM
AndeyHall's Avatar
Quote:
Has your problem been fixed?
Tags
60, 60l, 85, cycle, diesel, duty, ford, idle, idlet, normal, parameters, percent, percentage, pid, psd, understanding, vgt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
