Just my tail lights are out on a 2011 F250? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-28-2011, 11:52 PM
jbullfrog's Avatar
jbullfrog jbullfrog is offline
More than just a Handyman
jbullfrog is gaining momentum as a positive member of FTE.
Unhappy Just my tail lights are out on a 2011 F250?
I left town tonight and dad called to say I had no tail lights. I stopped and checked the book to see where the fuse is and couldn't find anything for the tail lights or parking lamps. I have brake lights, both rear turn signals and the tail lights blink when you lock it with the fob. The trailer socket shows I have trailer tail/marker working. Why don't my tail lights work?
It was a year old last week.
Old 06-29-2011, 07:59 AM
CA Diesel Guy's Avatar
CA Diesel Guy CA Diesel Guy is offline
CA Diesel Guy is starting off with a positive reputation.
on my 2001 i have the same issue and it was a trailer tow fuse in the box under the hood check it out. It was a 15a that did it for me. I also had no running lights or dash lights along with no tailights. Hope this healped!! Good Luck
Old 06-29-2011, 08:47 AM
jbullfrog's Avatar
My trailer plug has all of its lights working.
Old 06-29-2011, 10:00 AM
ninerM1000's Avatar
ninerM1000 ninerM1000 is offline
ninerM1000 is starting off with a positive reputation.
If you have dimmed down your interior lights to far it dims your park lights.
Old 06-29-2011, 12:27 PM
Boomer23059 Boomer23059 is offline
Boomer23059 is starting off with a positive reputation.
" If you have dimmed down your interior lights to far it dims your park lights."
You have got to be kidding me. Seriously. Please tell me that's a joke.
Not only would that be a stupid design, but the dimmer for the interior lights is barely usable. I go from no lights to interior lights on with almost no control.
Old 06-29-2011, 12:39 PM
HAHAHAHAHA!!!!!
Old 06-29-2011, 04:28 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is online now
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
I second the trailer tow fuse under the hood. This has popped a couple of times on me over the years for some odd reason.
Old 06-29-2011, 04:32 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Trailer tow fuses shouldn't have any effect on the truck lights, only the trailer plug.
Old 06-29-2011, 04:38 PM
jbullfrog's Avatar
All of my trailer functions are fine. My dash lights are fine. My mirror marker lights are fine. My front marker lights are fine. My high and low beams are fine. The rear markers will blink when you lock the doors with the key fob. They don't come on with the lights. I haven't found any fuses for them as of yet. My dealer is really not helpful with diagnosing anything.
Old 12-26-2012, 03:15 PM
DutchBlackie's Avatar
DutchBlackie DutchBlackie is offline
DutchBlackie is starting off with a positive reputation.
Had the same problem, the manual doesn't say which fuse is responsible for the taillight. After pulling about 40 fuses it turned out te be f30 15A (
Parking lamp relay, TT parking lamp relay
), almost impossible to reach by the way.
Old 08-10-2014, 07:31 PM
Jim Seivewright Jim Seivewright is offline
Jim Seivewright is starting off with a positive reputation.
hi have tail lights not working on 2011 f150 they come on for few seconds then go out
Old 08-10-2014, 09:13 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
I think the fuse is listed under running lights, same thing happened to my 2011 last winter.
Old 11-10-2014, 12:52 PM
wynberg535 wynberg535 is offline
wynberg535 is starting off with a positive reputation.
my tail light arent working
hey Guys,
ok so here the things i lost my tail light the other day and cannot figure out why, i have checked all the fuses as well as check the connections under my truck as i did get stuck in the mud last weekend but everything worked after that. i also lent my truck to my father who towed a trailer, i have checked fuse #26 witch i believe is the trailer fuse as i read here that may cause it. but #26 fuse in my truck is a square fuse that is a 30amp, am i checking the right fuse or is there something i should check?
Old 11-10-2014, 02:26 PM
did you figure this out cause the same thing happened to my truck, im wondering what your problem was?
Old 11-10-2014, 07:46 PM
jbullfrog's Avatar
Quote:
There is a fuse in the panel under the hood for them. I also had problems with my brake controller which may have caused it. I haven't had the problem since it was a week old 4+ years ago?
No tail lights or power to fuses stoverdr 1999 - 2003 7.3L Power Stroke Diesel 0 06-11-2015 03:55 PM
wiring issue SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-05-2014 12:59 AM
What number fuse are the trailer tail lights? bar20 2004 - 2008 F150 4 07-13-2010 09:48 AM
New trailer tail lights don't work? dangerranger10 Ranger & B-Series 4 07-03-2010 08:19 PM
No trailer tail lights, please help vancouverpower 1999 to 2016 Super Duty 7 01-27-2006 11:48 PM
Tags
2011, 450, a2011, back, blinkers, brake, change, f150, f250, ford, fuse, howdoyougetthetaillightoutofa2008f250, light, lights, rear, tail, taillights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
