Torque specs for lugnuts on aluminum wheels? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-28-2011, 09:30 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
Could someone tell me what the lugnuts should be torqued to on a 03 SD with aluminum wheels?
Thanks,
Old 06-28-2011, 09:34 PM
dlibson's Avatar
dlibson dlibson is offline
dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.
165 ft/lbs is the spec.
Old 06-29-2011, 12:21 AM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
My stock steel wheels required 140 ft/lbs. The aluminum wheels I have now (different lug nuts) are torqued to 115.
Old 06-29-2011, 08:06 AM
plgebbia's Avatar
Thanks guys! I guess that pretty much means real tight Reps sent.
Old 06-29-2011, 10:49 AM
Trey Trey is offline
Trey is starting off with a positive reputation.
If I have aftermarket wheels and lug-nuts should I not be tightening them to the Ford specs? I've noticed my lug-nuts are ever so slightly twisted from torquing them to 160-165 lbs. I have pro-comp 6059-1079's and whatever lug-nuts they gave me with them.
It never occurred to me that the torque specs might be different because the lug-nuts are a different composition metal.
Old 06-29-2011, 11:07 AM
Ian123's Avatar
I was told not to go over 125 lbs with mine to avoid jumping threads
Old 06-29-2011, 04:28 PM
dlibson's Avatar
165 ft lbs is for the factory wheels. If you have aftermarket, it could/will be different...
Old 06-29-2011, 10:17 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
I thought it was 150 lbs ft for factory nuts...
Old 06-29-2011, 10:58 PM
lakedweller's Avatar
lakedweller lakedweller is offline
lakedweller is starting off with a positive reputation.
Quote:
Most people will torque to 150 lbs.because they don't have a torque wrench that goes to 165 lbs. The proper torque is 165 lbs on factory wheels. I still have to get a 200 lb. torque wrench.....
Old 06-29-2011, 11:06 PM
Ford book for 99 super duty is 148 lbs ft..srw..Just looked. I have 2 wrenches that go to 250 and one to 400 lb ft. They may have raised it for later years..
Dick
Old 06-29-2011, 11:58 PM
Ian123's Avatar
I stand corrected the factory torque spec for mine was 150 lbs not 140. Either way I don't see where people are getting 165? Maybe it depends on which rims you have, mine were 18x8
Old 06-30-2011, 08:39 AM
Super08's Avatar
Super08 Super08 is offline
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
The spec for trucks with srw's from 08 and up is 165 lb/ft of torque. If I recall correctly both my 05 and 07 were 150.
Old 06-30-2011, 05:42 PM
JESTERxHEAD JESTERxHEAD is offline
JESTERxHEAD is starting off with a positive reputation.
You guys seriously torque all your lugnuts with a torque wrench?!?!?!?! thats got to take FOREVER!
do yourself a favor and buy a torque stick extension that is the right ft-lbs and hammer away with the impact....
Old 06-30-2011, 05:46 PM
here is the link for a 160 lb-ft torqe stick....they are VERY effective.....
Torque Sticks, Torque Sockets and Other Discount Tools
Old 06-30-2011, 05:48 PM
dlibson's Avatar
I don't torque them at all. I just use my impact...
F350 Lugnut torque? four-sixty-power 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-29-2016 08:25 AM
Question!! fordnut forever 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-24-2015 10:03 PM
Pic request, 17" dodge spare steel wheels on F100 Mdc9966 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-12-2015 09:39 AM
socket size for lug nut macguy 6.7L Power Stroke Diesel 12 06-29-2012 09:26 AM
rounded off wheel lugnut help? dcf4x4 1999 to 2016 Super Duty 17 04-29-2010 11:15 AM
Tags
2001, aluminum, f150, f350, ford, lugnuts, rims, specifications, spes, stock, tires, torque, truck, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
