1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Torque specs for lugnuts on aluminum wheels?
Old 06-28-2011, 09:30 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
Could someone tell me what the lugnuts should be torqued to on a 03 SD with aluminum wheels?
Thanks,
Old 06-28-2011, 09:34 PM
dlibson's Avatar
dlibson
dlibson is offline
165 ft/lbs is the spec.
Old 06-29-2011, 12:21 AM
Ian123's Avatar
Ian123
Ian123 is offline
My stock steel wheels required 140 ft/lbs. The aluminum wheels I have now (different lug nuts) are torqued to 115.
Old 06-29-2011, 08:06 AM
plgebbia's Avatar
plgebbia
plgebbia is offline
Thanks guys! I guess that pretty much means real tight Reps sent.
Old 06-29-2011, 10:49 AM
Trey's Avatar
Trey
Trey is offline
If I have aftermarket wheels and lug-nuts should I not be tightening them to the Ford specs? I've noticed my lug-nuts are ever so slightly twisted from torquing them to 160-165 lbs. I have pro-comp 6059-1079's and whatever lug-nuts they gave me with them.
It never occurred to me that the torque specs might be different because the lug-nuts are a different composition metal.
Old 06-29-2011, 11:07 AM
Ian123's Avatar
Ian123
Ian123 is offline
I was told not to go over 125 lbs with mine to avoid jumping threads
Old 06-29-2011, 04:28 PM
dlibson's Avatar
dlibson
dlibson is offline
165 ft lbs is for the factory wheels. If you have aftermarket, it could/will be different...
Old 06-29-2011, 10:17 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
I thought it was 150 lbs ft for factory nuts...
Old 06-29-2011, 10:58 PM
lakedweller's Avatar
lakedweller
lakedweller is offline
Most people will torque to 150 lbs.because they don't have a torque wrench that goes to 165 lbs. The proper torque is 165 lbs on factory wheels. I still have to get a 200 lb. torque wrench.....
Old 06-29-2011, 11:06 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Ford book for 99 super duty is 148 lbs ft..srw..Just looked. I have 2 wrenches that go to 250 and one to 400 lb ft. They may have raised it for later years..
Dick
Old 06-29-2011, 11:58 PM
Ian123's Avatar
Ian123
Ian123 is offline
I stand corrected the factory torque spec for mine was 150 lbs not 140. Either way I don't see where people are getting 165? Maybe it depends on which rims you have, mine were 18x8
Old 06-30-2011, 08:39 AM
Super08's Avatar
Super08
Super08 is offline
The spec for trucks with srw's from 08 and up is 165 lb/ft of torque. If I recall correctly both my 05 and 07 were 150.
Old 06-30-2011, 05:42 PM
JESTERxHEAD's Avatar
JESTERxHEAD
JESTERxHEAD is offline
You guys seriously torque all your lugnuts with a torque wrench?!?!?!?! thats got to take FOREVER!
do yourself a favor and buy a torque stick extension that is the right ft-lbs and hammer away with the impact....
Old 06-30-2011, 05:46 PM
JESTERxHEAD
here is the link for a 160 lb-ft torqe stick....they are VERY effective.....
Torque Sticks, Torque Sockets and Other Discount Tools
Old 06-30-2011, 05:48 PM
dlibson's Avatar
dlibson
dlibson is offline
I don't torque them at all. I just use my impact...
Quick Reply: Torque specs for lugnuts on aluminum wheels?
