A/C "shutting off"
are you sure it just quit, or could it have switched and been blowing out the defroster toward the window ? I cant think of anything that would shut the motor off completely other than loose electrical connection..... If it was blowing out the defrost, that can happen if you have a vacuum leak as the duct air routing is controlled by vacuum cylinders. Defrost is the default when you loose vacuum
Confirm what Steve mentioned re: if the airflow is coming from a different vent. If the blower motor stopped, you should be able to hear that change. Do you believe the blower motor stops?
The electronic controls should have a diagnostic mode that you can enter to have it tell you if it thinks everything is okay. There are position sensors on various doors so maybe if the airflow is being diverted, the self diagnostics can report that. I'll have to check tonight to see if I can get you the self diagnostic procedure. Or, if your warranty is a bumper-to-bumper warranty and the calendar time limit has not expired, you could have the dealer check in to it.
-Rod
-Rod
John Such
07-29-2011 11:55 AM
IES
07-06-2004 09:06 PM
