Correct Expansion Valve - Ford Truck Enthusiasts Forums
Old 06-28-2011, 06:49 PM
ydaveitsu ydaveitsu is offline
ydaveitsu is starting off with a positive reputation.
I've got a 1997 Ford Mark III conversion Van. It has the "Pro Air" Series 1100 A/C Heater unit installed. My question is, does anyone know a correct part number for the expansion valve for this unit. East Coast Toys who have parts for these Ford Mark III conversions want $65.00 plus shipping for their replacement. I'm use to spending 25-30 dollars for expansion valve. I ordered one for a Ford OEM rear air unit. Then I started thinking if this was going to work. Both units are rated for about 15,000 BTU's
Old 06-30-2011, 10:05 AM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
The Ford valve most likely will be different.
Most add on AC units are made from generic, off the shelf parts except for the housing itself. Take the valve to NAPA and match it up to one in their Climate Control catalog.
Why are you replacing the TXV? They rarely fail.
Old 06-30-2011, 06:45 PM
I did that today. Got the other expansion valve today in the mail. It looks just like the one that was in there. The only difference was the capulary tube was a little longer. I just gave it and extra coil. Both expansion valve even had the same casting markings on them. The reason I'm replacing it because when I had the whole system apart, I thought I would get smart and make sure the inside passage ways were clear of any crap. I took my allen wrench and uncrewed the valve. I counted the number of turns so I could put it back the same way. Well a long story short I guess I didn't. So when the unit was together, I was getting cold from the front A/C but not so cold from the rear. I checked the heater valve to make sureit was closing in the A/C position, and it was. So here I am replacing the expanion valve. I'm evacuating the system now and then put a new charge in.
Old 07-26-2011, 09:11 PM
Just wanted to update my situation with my van's A/C. I put the new expansion valve in the rear unit and I put in a new self adjusting orifice tube for the front unit. This orifice tube is made for high temp climates, 100* plus. I thought at first it was a sales pitch. I evacuated the system for about 4 hrs and gave it a new charge. The day I did this was 97 degrees. I was getting air out of the front vents about 42* at a stand still. When I drove the van on the road, the temp out of the vents dropped into the high 30's. The back vents were not as cold but were still in the high 40's low 50's. I am more then pleased with the outcome. The other day it was about 101-102 and I was still blowing air in the front vents in the mid 40's. I had to turn down the blower fan motors to low.
Old 08-05-2011, 05:06 PM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
Does it look like this one? Click that link below.
CLICK HERE >>>> Expansion Valve Internal
I also have the Externally equalized and the Block valve expansion vlaves in stock.
oirfice tube or expansion valve mudmagnet63 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-12-2016 08:34 PM
A/c expansion valve? Eli1644 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-25-2015 08:33 PM
Expansion Valve vs. Orifice Tube 86LariatXLT 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-09-2013 07:43 PM
Proper coolant filling method? fred_79f250 Expedition & Navigator 3 02-06-2012 10:37 PM
1970 Ford F250 4x4 dealer A/C pics and information?? tfmech 1967 - 1972 F-100 & Larger F-Series Trucks 19 08-23-2011 01:52 AM
Tags
2002, 96, ac, air, cold, conversion, correct, expansion, expedition, ford, iii, line, mark, mark3, parts, rear, valve, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
