torque spec on wheel bearings - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-28-2011, 05:26 PM
brucebowker's Avatar
brucebowker brucebowker is offline
brucebowker is starting off with a positive reputation.
I just replaced the front wheel bearings (inside one was all but non- existent) on my 1999 Ranger, 2 wheel drive. Is there a torque spec for the axle nut? I snugged them but not too tight. Wheel turns nicely.
Thanks
Bruce
Old 06-29-2011, 08:38 PM
awright48 awright48 is offline
awright48 is starting off with a positive reputation.
I just changed my rotors at a local DIY place and he had told me that you should tighten it just a bit and then back off about 1/4 of a turn. hope that helps
Old 06-29-2011, 09:16 PM
Does help. Thanks
Old 06-29-2011, 10:38 PM
reddog99 reddog99 is online now
reddog99 is starting off with a positive reputation.
Don't know if your '99 is the same, but for my 2004 the manual says to tighten the axle nut to 21 ft/lbs while rotating the disk. Loosen the nut 175 degrees. Re-tighten the nut to 17 in/lbs while rotating the disk.
Old 06-30-2011, 08:01 AM
Thanks. I would assume it must be very similar.
Old 06-30-2011, 10:41 AM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
reddog99's spec is what my 1994 shop manual also calls for. The 17 Inch pounds is the trickey one not many torque wrenches in inch pounds that are 1/2 inch drive for the 1 1/16 socket you need to use.
Old 06-30-2011, 11:03 AM
Yikes ! Misread that. 21 foot pounds followed by 17 inch. I thought 21 and 17 ft pounds. Glad I saw this again.
Old 06-30-2011, 12:43 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
from Haynes
1)17-25
2)backoff 1/2 a turn
3) 18-20
when I did mine I just did 25 then backed off then did 20......make sure you used the high temp grease and not the regular grease?
Old 06-30-2011, 07:31 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Quote:
Originally Posted by powersmoked View Post
from Haynes
1)17-25
3) 18-20
#1 is ft/lbs
#3 is in/lbs
Old 06-30-2011, 10:00 PM
Perfect.
Thanks
Old 07-01-2011, 05:44 AM
Quote:
Originally Posted by greenpus View Post
#1 is ft/lbs
#3 is in/lbs
wow..............Thanks fo rhte headsuo........ I never noticed that before...........that means I have my wheels bearings torque way to tight.........my wrench does not even go that low.......
Old 07-01-2011, 06:20 PM
My Haynes doesn't list those as well and it's in my Ford Manual.
I'm kind of **** with torque and I actually bought a torque wrench that is in in/lbs. Most people just tighten the nut and call it good. I guess that works too as long as the wheel still turns easily.
Old 07-01-2011, 08:17 PM
Speaking of Haynes - I want to get a manual. Which is better - Chilton or Haynes or both about the same?
Thanks
Bruce
Old 07-01-2011, 10:29 PM
Otahyoni's Avatar
Otahyoni Otahyoni is offline
Otahyoni has a good reputation on FTE.Otahyoni has a good reputation on FTE.
I've been doing all of mine the same, from my truck to a 20,000# disc wheel bearings.
Tighten it while turning the wheel, i get it pretty tight. Then loosen it a half turn or so (until its loose), then i tighten it with my fingers while turning the wheel.
In a perfect world you want 0.000" end play. Since you can't measure that, aim for.001-.003", measured with a dial indicator.
Old 07-02-2011, 07:45 AM
Quote:
Thanks
Bruce
I prefer Haynes over Chilton but anymore, I think they are about the same with leaving important info out. I also believe that both are made now by the same company but I could be wrong.
I started buying the "real" service manuals and I use the Haynes and Chilton as a quick reference. I bought this one for my 2000 a long time ago and don't regret the purchase. Click on the below link.
2000 Ford Ranger Service / Shop Manuals Set of 2 Books | eBay
08 Explorer Sport Trac WHeel Bearing/Hub Replacement GRNMSTR Explorer, Sport Trac, Mountaineer & Aviator 1 05-26-2016 02:49 PM
Torque Specs front wheel bearings?? TransBrain 1999 - 2003 7.3L Power Stroke Diesel 4 07-20-2014 06:19 PM
wheel bearing torque specs for 75 f100? NW 150 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-29-2012 07:39 PM
2wd wheel bearing torque specs johnsteffy 1994.5 - 1997 7.3L Power Stroke Diesel 3 09-23-2010 11:21 AM
dana 60 torque specs please!!! 68f250guy 1967 - 1972 F-100 & Larger F-Series Trucks 0 11-14-2009 04:00 PM
Tags
07, 1979, 1999, 99, bearing, e150, escape, f150, ford, ranger, spec, specifications, torque, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
