torque spec on wheel bearings
Old 06-28-2011, 04:26 PM
brucebowker's Avatar
brucebowker
brucebowker is offline
I just replaced the front wheel bearings (inside one was all but non- existent) on my 1999 Ranger, 2 wheel drive. Is there a torque spec for the axle nut? I snugged them but not too tight. Wheel turns nicely.
Thanks
Bruce
Old 06-29-2011, 07:38 PM
awright48's Avatar
awright48
awright48 is offline
I just changed my rotors at a local DIY place and he had told me that you should tighten it just a bit and then back off about 1/4 of a turn. hope that helps
Old 06-29-2011, 08:16 PM
brucebowker
Does help. Thanks
Old 06-29-2011, 09:38 PM
reddog99's Avatar
reddog99
reddog99 is offline
Don't know if your '99 is the same, but for my 2004 the manual says to tighten the axle nut to 21 ft/lbs while rotating the disk. Loosen the nut 175 degrees. Re-tighten the nut to 17 in/lbs while rotating the disk.
Old 06-30-2011, 07:01 AM
brucebowker
Thanks. I would assume it must be very similar.
Old 06-30-2011, 09:41 AM
wtroger's Avatar
wtroger
wtroger is offline
reddog99's spec is what my 1994 shop manual also calls for. The 17 Inch pounds is the trickey one not many torque wrenches in inch pounds that are 1/2 inch drive for the 1 1/16 socket you need to use.
Old 06-30-2011, 10:03 AM
brucebowker
Yikes ! Misread that. 21 foot pounds followed by 17 inch. I thought 21 and 17 ft pounds. Glad I saw this again.
Old 06-30-2011, 11:43 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
from Haynes
1)17-25
2)backoff 1/2 a turn
3) 18-20
when I did mine I just did 25 then backed off then did 20......make sure you used the high temp grease and not the regular grease?
Old 06-30-2011, 06:31 PM
greenpus's Avatar
greenpus
greenpus is offline
Originally Posted by powersmoked
from Haynes
1)17-25
3) 18-20
#1 is ft/lbs
#3 is in/lbs
Old 06-30-2011, 09:00 PM
brucebowker
Perfect.
Thanks
Old 07-01-2011, 04:44 AM
powersmoked
Originally Posted by greenpus
#1 is ft/lbs
#3 is in/lbs
wow..............Thanks fo rhte headsuo........ I never noticed that before...........that means I have my wheels bearings torque way to tight.........my wrench does not even go that low.......
Old 07-01-2011, 05:20 PM
greenpus's Avatar
greenpus
greenpus is offline
My Haynes doesn't list those as well and it's in my Ford Manual.
I'm kind of **** with torque and I actually bought a torque wrench that is in in/lbs. Most people just tighten the nut and call it good. I guess that works too as long as the wheel still turns easily.
Old 07-01-2011, 07:17 PM
brucebowker
Speaking of Haynes - I want to get a manual. Which is better - Chilton or Haynes or both about the same?
Thanks
Bruce
Old 07-01-2011, 09:29 PM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
I've been doing all of mine the same, from my truck to a 20,000# disc wheel bearings.
Tighten it while turning the wheel, i get it pretty tight. Then loosen it a half turn or so (until its loose), then i tighten it with my fingers while turning the wheel.
In a perfect world you want 0.000" end play. Since you can't measure that, aim for.001-.003", measured with a dial indicator.
Old 07-02-2011, 06:45 AM
greenpus's Avatar
greenpus
greenpus is offline
Thanks
Bruce
I prefer Haynes over Chilton but anymore, I think they are about the same with leaving important info out. I also believe that both are made now by the same company but I could be wrong.
I started buying the "real" service manuals and I use the Haynes and Chilton as a quick reference. I bought this one for my 2000 a long time ago and don't regret the purchase. Click on the below link.
2000 Ford Ranger Service / Shop Manuals Set of 2 Books | eBay
Quick Reply: torque spec on wheel bearings
