79 f250 super cab 4x4 - Ford Truck Enthusiasts Forums
Old 06-28-2011, 04:39 PM
boggin79ford boggin79ford is offline
boggin79ford is starting off with a positive reputation.
So i picked up this super cab a few months ago and have been working on it little by little. It is a lariat model so it came with all the bells and whistles like tilt column, intermittent wipers, lighted vanity mirror, and so on..I picked it up for $900 and about 5 hours of driving north to get it. it had a rebuilt 400 engine and c6 trans, np205 tcase with a dana 44 front axle and 60 rear.
heres when i first brought it home.
first thing i did was remove the camper
Old 06-28-2011, 04:44 PM
I then swapped in a front dana 60 with crossover steering and installed a 6" skyjacker lift and 37" tires. also put on my bumper with warn 12k winch.
i cleaned up the engine bay a bit and installed dual optima red tops, new super cooler radiator and a few other things.
Old 06-28-2011, 04:50 PM
Now im at the point where im swapping in a np435 manual trans. i had the trans rebuilt by a friend and i resealed the transfer case.
since im already going to have the rear drive shaft redone with 1350 yokes im going to swap in a 14 bolt with a detroit locker and disc brakes.
I just started tearing it down today and here is how it sits.
Old 06-28-2011, 05:13 PM
vic_v8 vic_v8 is offline
vic_v8 is starting off with a positive reputation.
they day you brought it home, was worth $3000 up here all day long.
Old 06-28-2011, 06:00 PM
kbrenner536 kbrenner536 is offline
kbrenner536 is starting off with a positive reputation.
Same here. This is the kinda find you only hear about and **** and moan cus you wish you found it haha.
Old 06-28-2011, 09:55 PM
PA74F250's Avatar
PA74F250 PA74F250 is offline
PA74F250 is starting off with a positive reputation.
What type of crossover setup did you use? I'd like to see some pics if you have some.
Thanks
Old 06-28-2011, 09:59 PM
70 Bronco TX's Avatar
70 Bronco TX 70 Bronco TX is offline
70 Bronco TX is starting off with a positive reputation.
Cursing you...nice truck!
Old 06-28-2011, 11:48 PM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
Are you rich or something?? haha
Old 06-28-2011, 11:50 PM
Quote:
Thanks
i got the steering arm off my buddies chevy dana 60 for free and i ordered the crossover tube and used chevy tie rod ends. i already had the drop pitman arm i just had to rotate it 90 degrees.
<embed id="ZeroClipboardMovie_4" src="http://pic.pbsrc.com/flash/ZeroClipboardFV2.swf" loop="false" menu="false" quality="best" bgcolor="#ffffff" name="ZeroClipboardMovie_4" allowscriptaccess="always" allowfullscreen="false" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" flashvars="id=4&text=%255BIMG%255Dhttp%253A//i32.photobucket.com/albums/d49/boggin79ford/Big%252520green/DSC00116.jpg%255B/IMG%255D" wmode="transparent" align="middle" height="100%" width="100%">
Old 06-28-2011, 11:53 PM
Quote:
haha i wish.... im broke i have been saving parts for a while now..
Old 06-29-2011, 12:10 AM
RednecksF150 RednecksF150 is offline
RednecksF150 is starting off with a positive reputation.
I wish I could find a deal like that....
Old 06-29-2011, 08:02 AM
ford141's Avatar
ford141 ford141 is offline
ford141 is starting off with a positive reputation.
Wow, very nice truck and a steal for $900. There is one very similar to that for sale locally for $5000. And he will probably get that for it.
Old 06-29-2011, 09:04 AM
PA74F250's Avatar
Quote:
<EMBED id=ZeroClipboardMovie_4 height="100%" name=ZeroClipboardMovie_4 type=application/x-shockwave-flash align=middle pluginspage=http://www.macromedia.com/go/getflashplayer width="100%" src=http://pic.pbsrc.com/flash/ZeroClipboardFV2.swf wmode="transparent" flashvars="id=4&text=%255BIMG%255Dhttp%253A//i32.photobucket.com/albums/d49/boggin79ford/Big%252520green/DSC00116.jpg%255B/IMG%255D" allowfullscreen="false" allowscriptaccess="always" bgcolor="#ffffff" quality="best" menu="false" loop="false">
Thanks. I was hoping you had a bought kit. I like the looks of the crossover and I'm sure it drives better than the push/pull. I'm in the middle of the D60 swap and it looks like I'm going to need a drop pitman arm and another drang link possibly. So I'm trying to decide if I should just go the crossover route.
Old 06-29-2011, 10:15 AM
NBC-Steve's Avatar
NBC-Steve NBC-Steve is offline
NBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to behold
That is a very good looking truck. Where did you find it? I'm about 5 hours North of you. Just curious.
Old 06-29-2011, 10:24 AM
I bought the cross over kit from Sky Manufacturing
1986 f350 4x4 crew cab diesel So Cal boggin79ford Vehicles for Sale 2 08-14-2015 09:42 AM
gm 14 bolt swap done!! boggin79ford 1973 - 1979 F-100 & Larger F-Series Trucks 39 12-30-2013 09:09 AM
looking for a 77-79 green f250/f350 4x4 boggin79ford WTB - Ford Trucks & other vehicles 11 05-27-2013 12:31 AM
WTB: ford superduty center caps boggin79ford WTB - Parts & other 2 05-11-2013 02:19 PM
on the cheap 85 f250 diesel 4x4 build boggin79ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 04-07-2013 11:04 PM
Tags
1979, 37, 4x4, 79, bay, dual, engine, f250, ford, kit, photos, supercab, tires, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
