Scan Gauge II - Boost issue, EOT temp? - Ford Truck Enthusiasts Forums
Old 06-28-2011, 02:52 PM
River River is offline
River is starting off with a positive reputation.
I finally bought a Scan Gauge II, and programmed it for EOT as well. Ran it this weekend up a grade to Big Bear.
Boost issue: It will read the boost pretty accurate to the dash gauge, but after it's been over 20 psi once, the next time it goes up there, the gauge goes to a negative number. Very odd. Any idea why? Eventually it settles back down to read correctly.
Also, truck was empty, good grades but only running about 40mph due to the curves. EOT ran about 220, while ECT was 209. And this is with zero load. Does anyone know if this sounds normal? Concerned what it will be WITH a load.
Other than that, gotta say I really like the Scan Gauge II, plus the fact you can program it to read all sorts of info. Nice for the $ and oh so easy to install!! Plug it in, velcro on, bam! You're off. No dash removal, wiring, etc. Thanks to those who kept bugging me to get one.
Old 06-28-2011, 03:51 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Try this:
Enter this MAP sensor as MAP:
Get reading.
Then re-enter this gauge except go down the chart for which ever the MAP says, then change accordingly. (name the second one boost)
Manifold Absolute Pressure (PSI) (BOOST)
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Old 06-28-2011, 05:35 PM
OK I did this. With key on, engine off, it read 14.5. I added the FF6F to the MTF code, saved it, but it still reads 14.5. Double checked, the FF6F saved, turned it off/on, started engine, still 14.5 when engine off or idling.
My truck is the 2006 PSD with the latest computer calibration from Ford.
Any ideas?
Old 06-28-2011, 08:40 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
You say you 'added' it to the map code ? Maybe you meant you replaced it... but
you should be replacing the last four characters with your FF6F like 01220320FF6F
Old 06-28-2011, 08:46 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
after cold soak make shure the SGII ECT,EOT,TFT temps are within a degree or two at startup tis will verify the SGII accuricy
and your eot vs ect numbers look good to me
might want to check FICM MP at cold start to
Old 06-28-2011, 08:54 PM
I overwrote the last 4 digits with FF6F, I did not delete the whole thing and start over. Is that what needs to be done?
Old 06-28-2011, 10:43 PM
Roasted7's Avatar
Roasted7 Roasted7 is offline
Roasted7 is gaining momentum as a positive member of FTE.
That scangauge is a pretty handy tool. Before I got mine I thought my truck was in great shape. Since I've discovered my oil cooler needs replaced, my FICM unit was going bad, and now I've discovered my alternator is dieing.
Just load tested the alternator tonight and it'll only put out 30 amps. Sucks, but I'd rather discover this way than get stranded somewhere.
Next I'll be watching the tranny temp.
Old 06-28-2011, 10:46 PM
Roasted7's Avatar
Here's some good xgauges if you don't already have them.
http://www.ford-trucks.com/forums/10...injectors.html
Old 06-28-2011, 11:01 PM
BLADE35's Avatar
that alternator could of took out your FICM, and maybe your batts next
how did you check amps [ inductive amp meter clamp]
Old 06-28-2011, 11:37 PM
Roasted7's Avatar
Auto parts guy had a tester. Batteries tested 1000 amps each and alternator only 30amps.
Old 06-29-2011, 05:38 PM
Any ideas?
OK, my MAP is automatically in the Scangauge II system.
So the above code should be named Boost, and should come up as BST in the Xgauge list, not in the stock SGII gauges.
Right now my MAP reads:
KOEO = 14.6
Boost = 0.2
So, I just changed mine to FF6F, which isn't 14.6. 14.6 gave me a -0.1 Boost.
14.5 gave me a 0.0 boost now.
Of course High or low weather pressure can have some effect.
Now I just put up Barometer reading, it shows 14.5, MAP 14.6, so it's off just a little.
Is any of this making sense? If you have 2 gauges named the same, one in SGII stock file, and one in the Xgauges, you might be only seeing stock reading.
Might just check your BAR reading also, and try re-entering the above code as boost.
My Boost gauge is exactly the same as the MAP above, except its named Boost and has the FF6F in the last four places in the Math line.
Sorry, just a convoluted way of saying the same thing sixteen different ways!
Old 06-29-2011, 10:21 PM
Thanks for the feedback. well it's strange but after checking the programming again, saving again 3 times, then toggling thru all the other settings, the boost finally came up as 0.00 and appears to be working now. Going to run 250 miles in the morning with some grades will check it out and see if it works better than the BST that was preprogrammed into it.
Old 06-29-2011, 11:01 PM
shawnna's Avatar
shawnna shawnna is offline
shawnna is starting off with a positive reputation.
*sigh*
Honestly guys, all of these posts seem so foreign to me.
I'm waiting for my new ScangaugeII to be delivered and it's scaring me thinking about programming it, much less understanding what it is I'm seeing once I do.
Isn't there a cliff notes version or "ScangaugeII for Dummies" guide or something?
Old 06-29-2011, 11:42 PM
don't worry. when you get it, use the big manual to set it up. it's easy. then read the 'X-Gauge' section if you want to program additional readings into it. Get the info on this site, it's super easy.
Old 06-30-2011, 02:46 AM
Would be interested on your findings. Do you have Fan speed set up? would like to see what you get with that.
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
Where did you get a SGII with a preprogrammed "boost"?
Mine wasn't in there when I got mine. I had first entered boost from the Xgauges page, and had the very same situation as you, negative numbers after 20 or so. Matter of fact, most did. James from Scangauge resolved our issues on this. Just hopw they update the website soon.
You will do fine.
Sean
High oil temp and gauge issue mdelfunt 6.0L Power Stroke Diesel 50 08-07-2016 10:13 PM
Updates on my PO299 while towing Mcrafty1 6.0L Power Stroke Diesel 2 07-20-2015 05:41 AM
Glow Shift Quad Pillar? 99ExpyProblems 6.0L Power Stroke Diesel 26 10-09-2013 01:47 PM
Wrench light and it isn't EOT/FWT tdh136 6.0L Power Stroke Diesel 12 05-21-2012 10:01 AM
EOT reading high with Scangauge hndacr 6.0L Power Stroke Diesel 10 06-02-2010 08:31 AM
Tags
60, 73, boost, eot, f250, ford, gauge, normal, numbers, parameters, read, scan, scangauge, scanguage, temp, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
