Hello from St. Marys Ga - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 06-28-2011, 03:02 PM
chevygirl_78 chevygirl_78 is offline
chevygirl_78 is starting off with a positive reputation.
Hey my name is heather and I live in St. Marys Georgia, about 15 minutes from the georgia florida line. I work at a local shop here in town, and am currently working on a 2006 E350 box truck with the 5.4 engine. I need some help figuring out what is going on with this truck. There is a vacuum leak in the ac system somewhere, but I can not figure out where. While at idle the ac blows out of the vents, but as soon as you start driving it blows out of the defrost. I have done a vacuum pressure check on the actuators in the dash, as well as the one by the passenger kick panel. I checked to make sure all the hoses were connected like they should be too. I dont hear an air leak anywhere, nor do i see any bubbles when soapy water is sprayed on the hoses. We are not equipped with a smoke machine, so that test is out of the question unless there us an alternative to that test. Can anyone help me? I also have a 2004 F450 tow truck that has an ac problem as well. The compressor does not kick on unless it is jumped, but the system has about 35 pounds or pressure in it. Could that be a high or low pressure switch?
Old 06-30-2011, 11:15 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
Hi heather, your best bet is to go in one of the sub forums here that is more specific to what your trying to figure out, as Ga chapter isn't exactly the busiest place on the site.
Welcome to FTE stick around there is plenty to learn here.
Old 07-07-2011, 11:12 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Ah another local of ours. Welcome.
New here: 1978 A/C help! astang 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-31-2016 10:32 AM
AC issues in me Ford Van fr420 1968-2013 Full Size Vans 9 07-24-2016 09:50 PM
Deice Switch or other AC Damper Assembly? Ira Brown Cooling, Heating, Ventilation & A/C 0 04-02-2016 11:07 PM
Why is my accumulator frozen when using heater? 1998Ranger25L153CID Ranger & B-Series 1 11-23-2015 08:54 AM
No Air from Dash Vents Mr Dave73 1997 - 2003 F150 1 11-27-2010 02:41 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
diesel, engine, ford, ga, georgia, heather, marys, model, repair, saint, st
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
