Accel's one piece 346s plugs - Ford Truck Enthusiasts Forums
Old 06-27-2011, 04:41 PM
theman79's Avatar
theman79 theman79 is offline
theman79 is starting off with a positive reputation.
i know that ford end of year 07 changed the head design and did away with the spark plug problem. but 05-07 still must deal with the two piece plugs.
brisk, champion, and accel make one piece plugs, but they aint cheap.
i'm posting here cause i ordered the Accel plugs 346S. everyone else paid like $80 for set of 4 that i found through all the forums. i paid $87.98 for all 8, with free shipping.
figured i'd spend the money, go with the one piece plugs. i'm at 64k now. these should get me to 120-140k. that's at least 5-7 yrs for me from now.
Accel Part No. 346S - Silver Tip Spark Plug Wire Repair Parts
Old 06-28-2011, 01:17 AM
thousand_mile_stare thousand_mile_stare is offline
thousand_mile_stare is starting off with a positive reputation.
Old 06-28-2011, 05:47 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
No one makes a true one peice plug for these motors. Folks seem to like to call this style one peice because it's more robust then the factory design. It's welded construction, so you make the call. It is less likely to break when it's time to replace the plugs, but if you install the motorcraft replacements properly, they too come out just fine.
My personal take is the motorcraft is a better plug but if these are what you want, by all means go for it. They should offer good performance with no chance of breakage.
Old 06-28-2011, 09:43 PM
theman79's Avatar
well didn't know they were just welded or somehow together but stronger. that's why i come here, the best info.
i generally use nothing but oe parts from a good part house here. but been doing lots of reading here. and it all goes either way. but gonna try these accel out. by time they need changing, unless they are junk, i'll hopefully be putting different heads and such on the motor.
currently, some things will arrive for it this week i hope. small lift. bilstein 5100's on all 4 with height adjustable for front with 2" lift, camburg's uca's to get rid of upper ball joints, tuff country 1.5" add a leaf. tough country 4" black pipe bumpers front and rear, blacked out all the badges today and ordered cool overlays for ovals. will be blacked out no chrome. just trying to find some all black 17" wheels and tires. then throw it all on for now. then down the road some new heads, headers and exhaust. should be nice
Old 09-18-2011, 09:05 PM
ryan70asu's Avatar
ryan70asu ryan70asu is offline
ryan70asu is starting off with a positive reputation.
How do you like those Camburg UCA's? They are pretty expensive but seem like a worth while upgrade. I have a 6" Trailmaster lift on mine and the factory ball joints are wearing out.
Old 09-18-2011, 11:19 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
The MC SP515's I got from Kragens/OReilly's for $8 each still look like 2pc designs. The thing is, unlike all of plugs I've replaced in my cars for the past 30yrs, these spun in very freely by hand until they seated. They must have reduced the diameter of the threaded shank so it will never be a problem. But it's not clear how they addressed the carbon buildup that welds the 2nd half into the head.
Old 09-19-2011, 07:47 PM
doofuss doofuss is offline
doofuss is starting off with a positive reputation.
I'm running Sea foam regularly. Also heard that Chevron is very good gas. I never thought there was a difference until I talked with an engineering consultant that did some work for them and said their refineries were head and shoulders above most others he had seen. So I'm doing a pound of prevention to prevent an ton of cure.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I'm Back!! New 2000 X to build!! All input welcome!!! ATG_Tuning Excursion - King of SUVs 32 12-20-2016 11:05 PM
56 Wiper blades dadgonebroke 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 02-05-2016 07:53 PM
A lil trivia. Super Duty Service 6.0L Power Stroke Diesel 19 12-23-2014 12:06 PM
Retro-Solutions HID Kit Installed woodnthings 1999 - 2003 7.3L Power Stroke Diesel 49 10-15-2012 04:29 PM
Accel Spark Plug wires subford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 02-12-2012 10:57 PM
Tags
04, 05, 07, 2004, 346s, accel, f150, ford, peice, piece, plug, plugs, properly, spark, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
