Funnel - Ford Truck Enthusiasts Forums
Funnel
Old 06-27-2011, 02:45 PM
rmchase rmchase is offline
rmchase is starting off with a positive reputation.
Funnel
My 2010 F-150 King Ranch has the gas fill with no cap. I am missing the "special" funnel that is supposed to come with the truck and want to purchase one. Does anyone know where I can get this piece. It is, apparently, made for use with the capless gas fill openings. I tried to fit other funnels but the truck will not accept anything but the piece made for this vehicle. Any help would be appreciated. Thanks.
Old 06-27-2011, 03:03 PM
jade97's Avatar
jade97 jade97 is offline
jade97 is starting off with a positive reputation.
If you have a Crew Cab, look under the back seat.
wchain wchain is offline
wchain is starting off with a positive reputation.
8U5Z-17B068B
Old 06-27-2011, 06:32 PM
fire240's Avatar
fire240 fire240 is offline
fire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputation
You can pick one up at the dealer. I had to replace mine a few weeks ago. Cost me about 13 bucks.
Old 06-28-2011, 05:22 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Wonder if you could make one from a plastic gas additive bottle (like Heat)?
Old 06-28-2011, 12:41 PM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
what he said ^... or next time you are at the pump, use a tape measure and see what the diameter of the nozzle is and find a funnel with the same size tip!
Old 06-28-2011, 12:52 PM
Hydrilla Gear Hydrilla Gear is offline
Hydrilla Gear is starting off with a positive reputation.
Just purchased my truck and say this funnel.. I have not filled with fuel yet.. Do I need to use this funnel? Can't Ijust stick the pump nozzle into the fuel fill??
Old 06-28-2011, 01:31 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
My understanding is that you only need the funnel if you have run out of fuel and you are NOT at a filling station.
i.e. side of the road with a 2 gallon can in your hand.
Old 06-28-2011, 03:08 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
You are correct sir! No need with a pump nozzle, just stick the nozzle in and fill 'er up.
Old 06-29-2011, 10:29 AM
funnel
The gas fill on the truck accepts a fuel pipe at the gas station ...no problem. If, however, you attemp to insert a funnel for the purpose of including a fuel additive or gas from a portable tank you need the special funnel made by FORD. I've tried other funnels and they do not work.
Old 07-01-2011, 08:33 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
how does the filler hole know what is being inserted and if it is right size or not? Cant push it down with a finger, but the special funnel and gas pump go in easily...sensors?
Old 07-02-2011, 05:53 AM
D8chumley's Avatar
Resident smarta$$
I DO know you will need the filler tube for adding any fuel system cleaner. If you just try to use the bottle it will wind up on your garage floor, it will NOT "seep" past the flapper. Ask me how I know
Old 07-02-2011, 11:59 AM
FireMe FireMe is offline
FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.FireMe has a very good reputation on FTE.
Quote:
There are two "buttons" on the side of the filler opening which must be depressed before the flapper will open. The correct size nozzle will engage these buttons and release the latch that holds the flapper closed.
Anything that can simultaneously depress these buttons will allow the flapper to open.
Look for a tapered-neck funnel and trim it shorter until the correct diameter is reached. Or, just buy the right part from the dealership.
Fuel Funnel Rick Cargo 6.7L Power Stroke Diesel 16 01-14-2017 09:47 PM
'98 E250 Fuel neck leak jerseymike 1968-2013 Full Size Vans 2 05-06-2016 08:36 AM
F250 Transfer Case Help Needed!!! tomspear 1999 to 2016 Super Duty 6 10-12-2012 11:18 AM
Good bottle for Diesel Fuel Additives??? Twin Tritons 6.0L Power Stroke Diesel 23 11-25-2004 11:36 AM
How to fill a dif. without a funnel Ray R Clutch, Transmission, Differential, Axle & Transfer Case 10 04-16-2002 07:47 AM
Tags
2009, 2010, 2011, buy, escape, f150, ford, fordfuelfunnel, fuel, funnel, gas, put, special, stick, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
