Front Brake Caliper Sticking.....and smoking - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-27-2011, 12:55 PM
River19's Avatar
River19 River19 is offline
River19 has a good reputation on FTE.River19 has a good reputation on FTE.
So a couple weeks ago my wife and I had the rig out for the 225 mile trip to our cabin and leaving with the rest of the weekend yahoos we got stuck in some pretty good stop and go traffic on the highway, I smelled some burnt pads after a few more aggressive stops and I assumed at first that a big rigs's trailer brakes were smoking.
Then a week later I was driving the same route when I noticed the same smell and the truck was pulling hard to the right.......I figured I had a sticky caliper.
Then today, short around town ride on a hot day and bang, pulling like a ticked off bride at a wedding dress sale.....get out at work, do the smell check on the front right and had some visible smoke coming out........so I tossed a bottle's full of water on the rotor and caliper and enjoyed the show.....
So, anyone else have this issue? Can I assume this is a "lube the caliper and replace the pads" type situation?
Man I hate the smell of stuff burning.......well at least the smell of stuff I own burning.....
Thanks
Steve
Old 06-27-2011, 03:05 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
This could be the problem, but you will not know untill you get them apart.
Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
Old 06-27-2011, 04:03 PM
River19's Avatar
MillerFeed - Thanks, what would we do without Guzzle.......
I have a good mechanic that I trust for brakes, maybe I'll order up two of those slide pin replacement kits and bring them on down with Guzzles tutorial as I just don't ahve the jack stands and space necessary to handle this job cleanly and safely.......although it would be a good excuse to get some.
I assume since brakes are relatively simple, (from a mechanical standpoint) that the pins sticking in the sleeves are the primary culprit to check out, right?
Thanks
Old 06-27-2011, 04:19 PM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
Yes....I agree with Rick on your brake problem.Do both sides and you will be happy again.
Old 06-27-2011, 05:53 PM
4EXTRDR 4EXTRDR is offline
4EXTRDR is gaining momentum as a positive member of FTE.
If u get into the habit of greasing those pins everytime u change the pads they will last...I leaned that the hard way servicing all my Ferds as they were all dry.
Old 06-27-2011, 09:30 PM
badhabit1 badhabit1 is offline
badhabit1 is starting off with a positive reputation.
Buy new caliper brackets and slide pins, jacks stands and even a jack, do it yourself and put the rest of the money you saved by not paying someone, in your pocket! Super easy job.
Brake caliper sticking 88 e150 annaleigh 1968-2013 Full Size Vans 15 11-11-2015 11:34 PM
Burned Caliper CollinsCD 1999 to 2016 Super Duty 12 10-10-2014 12:08 PM
Blasted Ford Braked NewEnglander 1978 - 1996 Big Bronco 0 08-17-2013 09:01 PM
2006 F250 SWR brake smoking (long) jc_doerr 1999 to 2016 Super Duty 14 08-20-2012 12:00 PM
Smoke/Burning smell from wheel well...Caliper? Mr_aerostar Aerostar 6 06-04-2011 02:07 PM
Tags
150, 2007, brake, burning, calipeir, caliper, calipers, f250, ford, front, navigator, smell, smoking, sticking, sticky, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
