main bearing cap bolts
Old 06-27-2011, 07:19 AM
Roy C's Avatar
Roy C
Roy C is offline
My son and I are rebuilding our first '87 4.9L engine. We ended up over-torquing the bolts on the main bearing caps due to misreading the manual. We got off on the wrong line. Anyway, one of them broke. Does anyone know where I can get a complete set? I'd like to replace them all if possible.
Old 06-27-2011, 12:05 PM
Harte3's Avatar
Harte3
Harte3 is offline
Try an auto parts house or machine shop.
Old 06-27-2011, 01:20 PM
Wyowanderer's Avatar
Wyowanderer
Wyowanderer is offline
I've got a set of brand new ARP studs I'll sell for $25.00 + the ride. Brand new, in the box.
Old 06-27-2011, 02:54 PM
Roy C's Avatar
Roy C
Roy C is offline
Everyone,
Thanks for the info. However I just went by the shop that did the head work and the guy has a 4.9L block that he doesn't need anymore so he's going to sell me the bolts out of it.
Old 06-27-2011, 02:59 PM
planehunter's Avatar
planehunter
planehunter is offline
As a precaution I would chase all the bolt holes with a tap, IMO.
Old 06-28-2011, 03:21 PM
f100jim's Avatar
f100jim
f100jim is offline
Not a good idea unless you have a GH1 tap. Most commonly available taps are GH3. They will cut the threads oversize, resulting in loose threads which will significantly weaken the threads. If you can run the bolts in by hand without them binding, don't chase the threads.
Old 06-28-2011, 05:28 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
Maybe it's just me, but when I have an old engine, and the main/head, rod bolts have been holding torque for 24 years, I think long and hard about fatique and stretch. There is a company called IIRC ... headbolts dot com? I believe, who have all the bolt for a 300.
Me, I'd rather spend an extra $40-$60 and know it is like the factory intended.
Good luck.
Nope, that site doesn't have them; only head bolt and many others. I know you have gone a different route, but ARP would be your best bet, anyone else searching for replacements.
The site I mentioned above also has the hard-to-find cam thrust plates!!
mogyver69
2004 - 2008 F150
06-02-2017 12:55 AM
PapaBearYuma
16
11-12-2016 10:42 AM
jakeharp
07-23-2016 01:53 PM
Cougar54
07-20-2014 04:30 PM
Rico82nd
13
10-28-2003 08:01 PM
Quick Reply: main bearing cap bolts
