1996 F-150 help
Old 06-27-2011, 06:31 AM
york57's Avatar
york57
york57 is offline
1996 F-150 help
Hi Folk's I hope someone can help me. I have a 96 F-150 5.8 4WD. Over the weekend i was driving had no problems then my Speedometer started jumping up and down and the ABS light came on and starting changing gears hard. I never thought I would make it home. i am no mechanic but i am pretty sure it is Electrical. i hope someone may have experienced it or have some input. i have a small code reader and hooked it up but did not see any issues, maybe mine is not precious enough to determine issue. Any thought would be appreciated since I can not get it into the shop for another 2 week's.
Thanks a bunch
Sam
Old 06-27-2011, 06:45 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Could be a problem with the Vehicle Speed Sensor (VSS). Should show up on your code reader.
The VSS is on top of the rear differential housing. You could try removing it and cleaning it. Also visually check the wires going to it for damage and check that the electrical pulg connection is clean and tight.
Old 06-27-2011, 07:01 AM
york57's Avatar
york57
york57 is offline
F-150 Electrical issue
After poting I had read some other post with similar issues. It sounds like you are dead on. I had called Auto Zone and they have it in stock and he advised the same thing. Going to try later this evening when part comes in i hope that is the fix. It all happened at the same time. thank you so much for the input.
Old 06-27-2011, 09:04 AM
subford's Avatar
subford
subford is offline
You might have better luck cleaning the old one if it is not in more than one piece.
You may not have much luck with the one from *****.
Old 06-27-2011, 11:48 AM
york57's Avatar
york57
york57 is offline
I got it folk's. As it turned out the Red wire leading to the Sensor was cut by my exhust. It was an easy fix cutters, wire nut, electrical tape Done. I never realized how much that affected. Thanks for your help finding the right area.
sam55ok
10-08-2019 01:25 PM
Supercab
08-06-2012 07:24 PM
Broomfieldbum
09-03-2009 11:17 PM
77 Bronco
12-30-2006 05:27 AM
knee_scraper
10-13-2004 07:29 AM
Quick Reply: 1996 F-150 help
