Squeelching belt upon startup (2011 F-150 5.0L)
Old 08-07-2011, 07:55 PM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
Hey everyone, I've got a 2011 F-150 FX4 Supercab with the 5.0L.
I've noticed that very seldomly when starting it up, something under the hood squeelch's very briefly. The trucks got 3019.0 miles on it as I write this letter. The actual noise itself come's and goes in less than 1/2 a second, and the trucks only made this noise 3 times during the 3000 miles I've owned it, and all the times have been fairly far apart.
I was wondering if this would be cause for concern? My old 1990 F-150 use to do this, but its issue was the bearings going out in the alternator. With only 3000 miles on my new truck the bearings should be a non-issue. Everything should be a non-issue for that matter. I'm not actually all that concerned about it, as I said in 3000 miles its only happend about 3 times...So once every thousand miles or so. And as I said the noise comes and goes in less than a second, and truck always runs just fine. Its never driven any differently.
Could this be attributed to all the heat we have been having lately? I live West Texas and right now 105 to 110 degree days are pretty much the norm, and have been for almost 2 months now. Could the excessive heat cause any to screech like that? And of course the truck has not been overheated, nor has it shown any signs of overheating.
Anyway I would like to hear everyone else's thoughts and ideas on it.
Thanks for the help.
Nate.
Old 08-07-2011, 10:14 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
OK, I'll giv'er a shot! If it only happens when it's hot outside, AND you start it w/ AC on, it might be the AC compressor starting with a lot of head pressure, the sudden load on the belt might be making it squeal.
Besides that, you might have the tensioner checked; it might be just a skosh UNDER spec for tension.
OR, the alternator might be under a heavier load than normal, which might, in combo w/ the above-mentioned under-spec tensioner(maybe) cause the belt to squeal.
I guess the question should be asked, does it sound like BELT squeal, or SEIZING BEARING squeal?
Anyway, here's some food (actually a feast...) for thought from my over-active imagination..... Hope you solve this.....
Old 08-07-2011, 11:16 PM
ebexp94's Avatar
ebexp94
ebexp94 is offline
"squeelch" - thats certainly a new one.
Old 08-08-2011, 09:46 AM
countryboy69's Avatar
countryboy69
countryboy69 is offline
if yours is an early built 5.0 there is and update to add a tensioner and pulley and new belt for the ac compressor. if your ac is directly routed to the crank pulley yours will need the update. tsb 11-07-01. this may fix your noise.
Old 08-08-2011, 04:24 PM
I don't think its an early built 5.0L I just picked the truck up on June 16th so I'm almost positive its a job 2 truck.
Old 08-08-2011, 05:27 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,220 Likes on 803 Posts
Check the sticker on the door jamb and that will tell you the build date. I bought mine in June but she was built in January.
Old 08-08-2011, 05:28 PM
tseekins's Avatar
tseekins
tseekins is offline
I just repped this person for a great post.
Old 08-09-2011, 09:43 AM
countryboy69
thanks for the reps guys.
Old 08-09-2011, 05:47 PM
Gary Atsma's Avatar
Gary Atsma
Have you found out anything yet (OK, this might be a bit early...)?
I guess my (above) pointers weren't that helpful in this situation....
Hey, I gave it a shot....
Dank Hill
04-25-2016 02:32 PM
Future_LEO
Modular V10 (6.8l)
09-19-2011 09:02 PM
chizzy matt
07-30-2011 08:01 AM
stupidjet
04-12-2010 10:17 PM
DOUG5G
Aerostar
10-04-2008 06:29 PM
Quick Reply: Squeelching belt upon startup (2011 F-150 5.0L)
