7.3 engine build
#76
#77
Thanks guys!
I was thinking with the money I have into the 38r and the bellowed up pipes I wasn't far off from going to another setup. Mostly for the rebuildable factor. I am also having turbo surge.
As much as I hate to say it, I think I may need to go with some different tunes as well. All my tunes are smokey and I can't really use my 100hp race cause my egt's get up way to fast. Jody tried changing a couple things but then I just get this is exactly how my tunes are set up for other people with my set up.
#79
Not quite sure. Not the cap I have tried a few and tested them all. Tried a couple thermostats and even no thermo stat. I have changed radiator and water pump. I have done compression tests as well as cylinder leak down. Everything passes. It will go weeks without out doing it and then will do it for a couple of days with no rhyme or reason and then quit.
#80
I was very happy with Gearhead tunes in the X (this engine w/AC's and S366). There is no comparison to my 'old' toons. Specifically no more smoke and EGT's are never an issue - EVER.
#81
#83
Did you inspect the coolant passages, specifically the cylinder walls? I wonder if this could be the problem?
What HG's did you use? How many miles on the engine now? What is max boost you've seen?
Is this enough ??????????'s
#84
Any indication of fuel in the coolant? Injector cup issue?
#85
#86
#87
#88
#90
There is no fuel in the coolant at all. I checked what I could for the coolant passages and did not see anything wrong that caught my attention. I am wondering if there is possibly a hairline crack in a cylinder wall but I assumed the would show on my leak down test. I am using cometic head gaskets .060" if I remember correctly. Really regret not having the pistons shaved and running stock HG's. I have just under 10k on it now. My boost gauge stops at 35 but I can bury the needle.
This could be the issue, I went through 3 sets of COMETIC head gaskets on my build. On mine, the gaskets couldn't stand high boost numbers. Finally gave up and after a LOT of inspecting, went back to stock head gaskets,the clearances are real close but no more issues..
