7.3 engine build - Page 7 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
7.3 engine build
  #91
Old 09-26-2013, 09:16 AM
jkidd_39's Avatar
jkidd_39 jkidd_39 is offline
jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.
Quote:
Originally Posted by joeyd61 View Post
This could be the issue, I went through 3 sets of COMETIC head gaskets on my build. On mine, the gaskets couldn't stand high boost numbers. Finally gave up and after a LOT of inspecting, went back to stock head gaskets,the clearances are real close but no more issues..
What kind of clearance you seeing??
  #92
Old 09-26-2013, 10:06 AM
joeyd61's Avatar
joeyd61 joeyd61 is offline
joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.
Quote:
regretfully, it has been over a year and I forget, I will go through my build sheets when I get home and see if it was wrote down..
  #93
Old 10-07-2013, 04:24 PM
88f1504x4's Avatar
88f1504x4 88f1504x4 is offline
Powerstroke Doctor
88f1504x4 is starting off with a positive reputation.
I have had the idea of that in the back of my head. It seems that its only high boost that the coolant is blowing out. I just hate the idea of having to tear the motor back down to have my pistons shaved to clearance..
  #94
Old 10-07-2013, 04:35 PM
88f1504x4's Avatar
Powerstroke Doctor
I was just talking to my machine shop. He recommended before going as far as shaving the pistons to use what they call a saver shim. He says its a steel shim that is used to allow the stock head gasket to be used. Does anyone have any experience with these? I'm thinking it can't hurt to try.
S.B. International e-Catalog Saver Shims
  #95
Old 10-07-2013, 06:39 PM
Bonanza35 Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Never heard of them. I guess you could be the first so we could all find out if you would report back after several miles. Without looking back threw this tread, how much was shaved off? I seem to remember only 10 thousands or so. Is this right. If so you should have know problem at all.
  #96
Old 10-09-2013, 01:06 PM
88f1504x4's Avatar
Powerstroke Doctor
Yea I am thinking I will give it a try in November, I don't have much to lose. I was told by the first shop 10 thousandths was taken off. When the pistons were installed if I remember correctly the piston protrusion was 20 thousandths over spec.
  #97
Old 10-09-2013, 03:52 PM
Did they take it off the heads or block? Did you own the truck since new? If so I won't think the 10 thousands they took off would hurt anything and they are wrong. But if some buddy else had the truck you don't know what they did before. More than one person on here has taken 10 off with know problems except trying to use none stock head gaskets.
  #98
Old 10-10-2013, 02:29 PM
88f1504x4's Avatar
Powerstroke Doctor
I have had to truck since 05 with about 80k on it. The first machine shop I took it to did a bunch work on my block without calling first. They were the ones that claimed they took 10 thousandths off. After that I went to another machine shop. I got the short block back so I seen the piston protrusion myself too know it was way too much.
2001 7.3 Powerstroke - Custom Build 400-450HP 7.3 PStroke 1999 - 2003 7.3L Power Stroke Diesel 46 08-09-2016 08:48 AM
Anyone use a 6.0 Intercooler? 650 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-01-2016 05:36 PM
4.6L DOHC people, need advice mustangmike6996 Modular V8 (4.6L, 5.4L) 0 01-25-2015 03:17 PM
?? about thermactor setup during rebuild (Piston, Cam, Intake swap) lazzarruss 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-27-2014 06:00 AM
New Build on the Six-Point-Oh SuperVossen 6.0L Power Stroke Diesel 3 08-27-2013 11:11 PM
Tags
1996, 1999, 26, 73, 73l, build, country, difference, engine, ford, guide, kit, leveling, painted, tough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
