7.3 engine build - Page 4 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
7.3 engine build
  #46
Old 02-01-2012, 11:56 AM
88f1504x4's Avatar
88f1504x4 88f1504x4 is offline
Powerstroke Doctor
88f1504x4 is starting off with a positive reputation.
For tunes I already have the DP F6. I would have liked to go to a bigger turbo but 2 weekends ago my stock turbo blew up and I need my truck everyday so the gtp38r was my best bet at the time.
  #47
Old 02-01-2012, 03:42 PM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
Back pressure can get insane with the 38R and 250's too just FYI. I'm a believer in having a properly sized turbo to injectors, but thats just me.
  #48
Old 02-01-2012, 07:53 PM
caverjoe's Avatar
caverjoe caverjoe is offline
caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.
Quote:
Originally Posted by SkySkiJason View Post
I 2nd this opinion. The trend is such that soon 'stock nozzles' may not be very common. Good tunes should be able to make 238/100's or even 250/200's work fine with a 38R - albeit 'detuned' for that charger. Too bad ya didn't spring for a T4 mount and standard-rotation turbo... Its not much more than 38R and bellowed uppies and soooooo many more options for upgrades!
Bigger nozzles mean more fuel in less time. This gives more time to add fuel BTDC without excessive timing advance. Getting the fuel in there 'early' means lower EGT's and better MPG's. I've spent some time behind the wheel of a truck with 250/200's and a GTX 4294. It drives like a stock truck (even in 'race' tune) and often gets 18+mpg - 4x4 Crew Cab. In 'stock tune' and 'daily driver' (400/450HP?) you really can't make it smoke, but trying to get some black smoke reduces the amount of tread on the tires! Even in the hottest tune, the smoke is gone in 60ft (GTX 4294 )... The owner has also towed 17k lb trailer and reports lower-than-stock EGT's.
I didn't see a tuner mentioned, but I would recommend visiting with a couple of tuners and getting their opinions about injectors. Swamps, Tyrant and Gearhead all have good tunes for big nozzles.
Digging the red/black too! Reps sent! I did black/blue on the dually, but thinking the engine I'm building for the X might look like yours...
Just trying to take notes here.
So just curious what is the price diffrence between the 38r conv. vs. GTX4294??
I like the sound of that GTX set up. Cant wait till I get started on my spare. Does anyone know of a good machine shop around the Kansas City area??
  #49
Old 02-01-2012, 07:58 PM
jkidd_39's Avatar
jkidd_39 jkidd_39 is offline
jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.jkidd_39 has a great reputation on FTE.
A gtx is around $2k iirc. And then $1250-1500 for a mount kit.
What kinda machine work do you need done??
  #50
Old 02-01-2012, 08:03 PM
caverjoe's Avatar
Just to check out the spare motor I bought, and have it bored, decked, etc if need be.
Plan on buiilding that one and swaping it out with my current E99.
Just want to get this stick turbo thing figured out so there are no regrets. I drive mine every day pulling a 14ft enclosed 5-7k. looking to build a 450hp give or take a little. Just need reliability since it is my money maker. MPG wont hurt at all either.
dont mean to Hyjack
  #51
Old 02-01-2012, 11:09 PM
88f1504x4's Avatar
Powerstroke Doctor
I have been trying to decide on sticks since June and i still haven't decided yet lol narowed it down some but thats it. Thats a lot of money to put in the wrong direction
  #52
Old 02-01-2012, 11:26 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Quote:
Originally Posted by indyF-350psd View Post
never understood tuning down bigger sticks for a sub par turbo.....if you get the big sticks then go with a proportionate turbo.....if you are not gonna get a bigger turbo then you might as well get the smaller sticks.....jmo....
Money my friend. What after spending on machining, pistons, springs,cam,head studs,sticks, then factor in the wife and there is ya answer
  #53
Old 02-01-2012, 11:34 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
you can't fix stupid!
indyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to behold
Quote:
imo....its cheaper to buy what you need up front than to buy what you can afford only to spend more upgrading later......the guys who convert from e99 to late 99 setups i think is nuts.....you can buy an h2e setup with bellowed uppies for the same price minus the intakes.........the wifey saying i thought you already bought a turbo, what do you need another one for.....is what will get you into trouble.....
  #54
Old 02-01-2012, 11:35 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Quote:
I'm of the "bigger is better" opinion... I would rather have large sticks tuned down than small sticks that are maxed out....or have to upgrade because they were too small.
My end goal is a 500+ HP rig... I plan on buying 250/200's when the time comes. But time will tell.
  #55
Old 02-01-2012, 11:43 PM
jkidd_39's Avatar
Agreed. Well put sir
  #56
Old 02-02-2012, 01:03 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Depends on where you live. Some places with smog you can't just throw any turbo you want on and get it registered. And if you look at the intake on the e99 they are very restrictive. Not meant to disagree completely just a fact here in the great state of California b---t.
Chet
  #57
Old 02-06-2012, 09:20 PM
caverjoe's Avatar
Hey Bill,
Can you point me in the right direction on that H2e setup??? I have a e99 that I am adding to right now, but have a late motor in my building that I plan on rebuilding. I want to put stuff on my running motor right now that I can use on my new motor after it is built. I was thinking of the early to late conversion but would like to know about every option.
thanks
Joe
  #58
Old 02-06-2012, 09:23 PM
caverjoe's Avatar
Quote:
Chet
So why cant I upgrade the intakes as well???? Or why wouldnt you??
thanks
  #59
Old 02-06-2012, 10:41 PM
jkidd_39's Avatar
Hey Bill,
thanks
Joe
Clay should be able to set you up with a kit. Beans diesel performance also has them. Iirc you will need to update to late 99 plenums. Talk to clay about them. He will set you straight.
The h2e can be modded in the future when you need more air. And the charger can be totally rebuilt. The hypermax kit is pricey but there are other options, Carson staffer makes a reasonable kit too. Just look for a T4i flanged kit.
thanks
The whole Cali check thing is bs. Just find some place that's cool with it. Do what you want. If anything it's cake to swap an intake back in for a check. 15 minute job including taking time to text and drink a beer
  #60
Old 02-07-2012, 12:16 AM
I didn't say you can't update the intakes. I just did this myself. Its the turbo type they look for here in california. The 38R is the closest to stock looking out there. The H2 and others are completely different looking, I would love to try them it just won't pass. And it ain't that easy to find a cool guy to do so as stated.
Chet
2001 7.3 Powerstroke - Custom Build 400-450HP 7.3 PStroke 1999 - 2003 7.3L Power Stroke Diesel 46 08-09-2016 08:48 AM
Anyone use a 6.0 Intercooler? 650 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-01-2016 05:36 PM
4.6L DOHC people, need advice mustangmike6996 Modular V8 (4.6L, 5.4L) 0 01-25-2015 03:17 PM
?? about thermactor setup during rebuild (Piston, Cam, Intake swap) lazzarruss 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-27-2014 06:00 AM
New Build on the Six-Point-Oh SuperVossen 6.0L Power Stroke Diesel 3 08-27-2013 11:11 PM
Tags
1996, 1999, 26, 73, 73l, build, country, difference, engine, ford, guide, kit, leveling, painted, tough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
