horn blows by itself - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-26-2011, 07:13 PM
homer01's Avatar
homer01 homer01 is offline
homer01 is starting off with a positive reputation.
Sitting in the house, heard a horn blowing and ran outside to find my F350's horn was blowing. When I pushed on the horn button on the steering wheel it quit. Couple of hours later, it started blowing again. Pushed the horn button to make it stop and removed the fuse so it would not start blowing again. Did a forum search, but didn't have any luck. Any ideas? Short in steering wheel?
Old 06-26-2011, 07:38 PM
hotroddsl's Avatar
hotroddsl hotroddsl is offline
hotroddsl has a very good reputation on FTE.hotroddsl has a very good reputation on FTE.hotroddsl has a very good reputation on FTE.
Has it ever had the air bag replaced?
Old 06-26-2011, 11:29 PM
be250 be250 is offline
be250 is gaining momentum as a positive member of FTE.
hey, samething,happen to my excursion ,bro.in law [mech] cked out in the air bag [30k never wrecked],had good ford extened warr. they said it was covered but they had to ck out,so after $100 ck out, well its not covered . so a very happy custmer, haha ,barry
Old 06-27-2011, 06:58 AM
homer01's Avatar
Never replaced air bag, but did replace the horn some months ago.
Old 06-27-2011, 08:39 AM
hotroddsl's Avatar
What you described usually only happens with replacement air bags but if the fabric is folded too loosely as the plastic gets hot it expands at a slower rate than the fabric causing the horn to honk until the steering wheel heats up to expansion as well!
Old 12-31-2011, 03:08 PM
Mtrdepy Mtrdepy is offline
Mtrdepy is starting off with a positive reputation.
I've had the same problem on my 06 F250. Parked and locked and the horn goes off. does any one have any Ideas. Also does anyone have any idea where ford hid the Horn Relay...
Old 01-13-2012, 01:13 PM
Engalwood Engalwood is offline
Engalwood is starting off with a positive reputation.
BUMP. My 2002 F250 does this as well. What can I do to fix it? The airbag has been replaced before. Ladyran a red light and pops smoked her, then proseeded to the BIG LIMESTONE wall at the Childerns Museum. NOT his fault, but any who. What can I do to fix this. Church Brothers was the place that fixd her. For the recored I dont like them anymore. Unno maybe just the one thats downtown.
Old 04-15-2014, 09:37 PM
Old Time RV'er Old Time RV'er is offline
Old Time RV'er is starting off with a positive reputation.
horn blowing
What did you guys ever do about the horn blowing?
Do I have to get the air bag replaced? Or the cover that has the switch in it.
I read all these forms and all I hear is pull fuses and check relay. I had the Ford dealer tell me there is no relay it is built into the back of the fuse box and have to replace the whole thing.
The expanding air bag makes sense but what do we do?
Someone please help
Old 05-25-2014, 02:40 AM
BigRy's Avatar
BigRy BigRy is offline
BigRy is gaining momentum as a positive member of FTE.
Back to the top with this thread, Started happening in my Excursion, had to remove fuse to get her to quiet down. Forget to mention, I have Nathan Airchime K3LA train horns with a 6 gallon air tank, can we say HOLY SMOKES while driving down the road on that one!!!!!!
Old 05-25-2014, 06:56 AM
je5 je5 is offline
je5 is starting off with a positive reputation.
It may be a failing clock spring in the steering wheel.
Do all the trucks in question have a security system that blows the horn if vehicle is tampered with? Do you have a panic button on your key remote that blows the horn?
Old 05-25-2014, 07:44 AM
BigRy's Avatar
I have an aftermarket alarm in my truck. I'm going to remove the airbag tomorrow and inspect the board and wiring around the clock spring. I'd rather do this than try to track down a faulty ground wire, but I guess easiest is the way to go for now.
Old 05-25-2014, 08:08 AM
je5 je5 is offline
Please be careful. Remove battery connection and wait at least 20 minutes before proceeding. Deployment can possibly kill you.
Old 05-25-2014, 09:38 AM
The Fix
My previous reply and comments is somewhere in this thread of another one, But this thread popped up this morning so I thought maybe this might help.
Your Clock Spring is bad. Plain and simple. Costs $170 at the dealer, maybe $90 aftermarket. Takes maybe 30 min max to replace with no hard work. a steering wheel puller and a couple of screw drivers.
search YouTube, there is a couple of videos detailing it.
I read a lot of different things... air bags expanding, relays, shorted wires.... but really think just people guessing.
Old 05-25-2014, 09:53 AM
Y2KW57's Avatar
Y2KW57 Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
That blows!
Old 05-25-2014, 11:28 PM
BigRy's Avatar
Cool deal, Old Time RV'er. I assumed that to be it but I wasnt sure. I have a local overstock parts house near me to where I can get a new OEM one for 78.00 bucks, so I'll give it go.
Thanks
I'll report back...
Horn Switch Bypass Questions TxWolfman 1999 to 2016 Super Duty 7 07-08-2016 12:43 PM
Horn sounds on its own Bosko 2017 Super Duty 1 08-18-2015 02:56 PM
64 F-100 Horn problem sleddog60 1961 - 1966 F-100 & Larger F-Series Trucks 5 05-18-2009 10:29 PM
How does the horn circuit work? daggerNC 1961 - 1966 F-100 & Larger F-Series Trucks 18 11-07-2004 08:28 PM
74 F100 horn doesn't work JStan 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-17-2003 07:23 PM
Tags
06, 2005, 2007, 2009, blowing, blows, crank, escape, expedition, f150, ford, horn, stering, wheel, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
