HELP!!
06-26-2011, 04:28 PM
HELP!!
well lol now i got your attention! well i need a cure for the pms i have been having within the last month i have put in stage 1 injectors, intercooler, 17deg hpop, trans cooler, dp tuner gauges, kicker subs, and next i will be getting rid of the midship tank due to internal rust and replacing the rear with a 38 gal tank as well as removing the fuel tank switcher. is there a cure for pms? if so let me know immediatly!
06-26-2011, 05:56 PM
on
Run out of money is the only known cure thus far. Research has been put on hold do to budget cuts.
06-26-2011, 08:07 PM
Ya just gotta stay away from that "add to cart" button"!
06-26-2011, 08:09 PM
on
Quote:
Originally Posted by
bad12jr
Research has been put on hold due to budget cuts.
The Budget was cut because everyone researching PMS has PMS and thus spent the budget on mods....
06-26-2011, 08:25 PM
on
Replace the midship tank, and still change the rear tank...
Never know when you'll find cheap diesel.
06-26-2011, 11:39 PM
pjwoolw
Pete, its that little box to the left of the "add to cart" button. Instead of one item, the budget gets into trouble when two or more is entered.
06-26-2011, 11:57 PM
LOL thats another one to stay away from for sure Glenn!
06-27-2011, 12:16 AM
sounds like you should have stuck with the idi there rodney haha
06-27-2011, 05:54 PM
bad12jr
research meake me want the item even more
pjwoolw
I know i got to lol
ReFlectiveMan
diesel is 3.69 here
06-27-2011, 05:55 PM
oreocreaming
I would like to have both tho but had to pick between the idi or the cc
powerstrokeddiesel
08-29-2008 08:00 PM
Medic 66
20
08-09-2008 09:17 PM
nhill2090
457
06-26-2008 10:24 AM
GeoffNJ
41
06-23-2006 04:27 PM
otterdiver
04-26-2006 12:24 PM
