94 Ranger 2.3L - Timing off or bad Crank Sensor? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-26-2011, 04:37 PM
cmccul002 cmccul002 is offline
cmccul002 is starting off with a positive reputation.
Hi all,
I replaced the timing belt a year or so ago. Since then it hasnt run great, but nothing like now.
It won stay running when cold. You have to hold the gas until it gets warm and even thenm it idles erratically and you can hear slight misfires in the intake.
Found no spark on cylinders 2 & 3 on exhaust side. Swapped coil, same issue. So I got a ICM from the junkyard and while replacing it I found out that on the wire harness from the Crank Sensor, it has the main connector and then a single wire Ground Connector for the shielding. Well that ground connector was disconnected (broken)
I fixed that and replaced the ICM. Now getting spark on those 2 cylinders, but didnt really change much. I have also replaced the IAC valve and coolant sensor.
I decided to test the timing. I disconnected the SPOUT (I think, it was a single connector with 2 pink wires with a plastic plug in it) and used a timing light and it was showing 15, with Spout In it was @ 20, that isnt right is it?
Could timing be off a tooth or 2 or bad crank sensor?
Any help is appreciated
95 5.0L ICM/TFI Quesitons jgrohs54 1987 - 1996 F150 & Larger F-Series Trucks 7 01-21-2016 11:43 AM
No spark issue-- actually, single spark..? exidor12 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-13-2015 07:34 AM
Another new guy looking for help grmtnmn New Member Introductions 0 09-01-2015 12:46 AM
Code 18, Spout Grounded/spark word angle failure. Pleasr help! kc135cruechief Electrical Systems/Wiring 10 11-17-2007 08:53 PM
Stalling / No start / Tach Jumping w/ key on / code 14 acc7484 Electrical Systems/Wiring 2 08-11-2005 11:22 AM
Tags
23, 23l, 93, 94, 97, check, crank, crankseneor, ford, ranger, sensor, set, test, testing, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
