How to replace freeze plugs? (1986) - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-26-2011, 01:11 PM
neumayr83 neumayr83 is offline
neumayr83 is starting off with a positive reputation.
I was just wondering what you need to do to replace the freeze plugs in a 1986 ford ranger. It is a 2.9L 4x4 5 speed
Old 06-26-2011, 04:23 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Are you replacing 1 in particular or all?
If you are doing all, it is required to pull the engine out.
Old 06-26-2011, 07:49 PM
mmxchamp mmxchamp is offline
mmxchamp is starting off with a positive reputation.
I half-a$$ed replacing one in my aerostar...it was leaking through the center of the old freeze plug. I drained the coolant, pulled the old one out with pliers/screwdriver and put in one of the rubber ones. Since I didn't have room to get a hammer in there to put a new brass one in, i got the rubber one. you put it in loosely, and then tighten the nut which compresses the rubber and makes it seal. i think it was like $8 at autozone.
Old 06-26-2011, 08:37 PM
Quote:
Has that worked out?
Old 06-26-2011, 09:11 PM
It held up for 4 years; I just got rid of the van a few weeks ago and it wasn't leaking or anything. I torqued it down a bit too much and ended up warping the washer on the outside that makes the rubber expand, and despite that it still held up. I would have put a brass one in, but there just wasn't enough clearance. if you have room to access it, I'd go ahead and put a new brass one in. Pretty sure they sell kits of 10 or so brass plugs at most auto parts stores for $20, if you need to repair more than one.
The plug I used looked something like this; the metal was all brass though and it was bigger so the nut on the top looked smaller.
Amazon.com: Dorman 570-003 Expansion Plug 3/4" - Pack of 5: Automotive
Freeze plugs bass-n-fire 1994.5 - 1997 7.3L Power Stroke Diesel 0 12-29-2016 03:37 PM
freeze plug wtroger Ranger & B-Series 0 10-31-2016 09:16 PM
throttle body freeze plugs leaking szealuss 1987 - 1996 F150 & Larger F-Series Trucks 0 10-17-2010 11:40 AM
1994 F-250 V8 460 - Freeze Plug handymanken 1987 - 1996 F150 & Larger F-Series Trucks 2 09-07-2010 11:02 AM
Block Heater is leaking? Dbailey Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-09-2010 11:05 PM
Tags
1986, 1987, 29, 460, 93, aerostar, f250, fi, ford, freeze, located, location, locations, plug, plugs, pug, ranger, repair, show
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
