No spark, unplugged computer and spark returned
Does this mean for sure I need a new computer? I had no spark or fuel pressure. I read on another post to unplug the computer and see if the spark returned, which it did, so I wanted to know if changing the computer will take care of the fuel issue also? any help would be appreciated. Thanks
The following users liked this post:
Yes more than likely a new computer will being the fuel pressure and spark back.
You also need to check and make sure the power pins on the computer have power and the ground pins read zero to ground.
If no ground check the small black wire with a green stripe coming off the NEG post of the battery and make sure it is well grounded there.
Thanks alot! I will check those points tommorow. If the pos. and negs. are correct to get the truck working will be to get a new computer right? If they don't check out, then fix the wiring issue so they do check out, then the computer is probably fine and it was the wiring all along. Did I understand the big picture correctly? I am capable in simple engine work, but I get lost easily when it come to wiring. thanks again
