Rear Window on Cap Broken - Solutions? - Ford Truck Enthusiasts Forums
Old 06-26-2011, 10:17 AM
The Grinch The Grinch is offline
The Grinch is starting off with a positive reputation.
Question Rear Window on Cap Broken - Solutions?
The rear window on my truck cap broke recently. Window lifts failed and it slammed down shattering the rear glass. Any solutions and methods to replace it short of sending it back to the SnugTop Dealer for a replacement?
Plexiglass,PolyCarbonate, metal, wood? How to cut it to keep from damaging a whole sheet?
Old 06-26-2011, 11:04 AM
RustyGreen's Avatar
RustyGreen RustyGreen is offline
RustyGreen is starting off with a positive reputation.
I was thinking make a template out of construction paper or cardboard to get the fit of the whole window channel it would sit in. And to keep from cutting a bunch of curves and angles out of plastic or plexi, make it out of a wood panel, and cut out a square portion of the middle the attach a clear panel or plexi to the back of the panel. This would give you more visibility than a solid piece. And depending on how much a plexi or plastic panel costs, you could vary the size of the opening
Good Luck, and hope I gave you an idea.
Power window sluggish 12valveEx 1968-2013 Full Size Vans 3 09-12-2016 02:29 PM
Broke The A.R.E. Cap Rear Window ls973800 1997 - 2003 F150 3 10-26-2010 09:10 AM
leaky roof, or window?? anyone else? koalamazed Aerostar 33 05-23-2009 12:09 AM
How to clean rear window w/cap? Club Wagon 1997 - 2003 F150 7 03-27-2009 12:45 AM
Rear sliding window lock dep295 1987 - 1996 F150 & Larger F-Series Trucks 1 11-02-2008 07:13 PM
Tags
1987, back, broken, canopy, cap, caps, cover, ford, glass, install, plexi, rear, square, topper, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
