Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
  #241
Old 01-06-2015, 09:08 AM
whd507's Avatar
whd507
whd507 is offline
I just picked up a microfische machine and several boxes of slides from a ford dealer. looks like 1957 to the mid 90s. does this stuff have any value?
  #242
Old 01-06-2015, 09:53 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Is the microfiche reader an ultra VII .. and does it work?
I'd be interested in the slides.
  #243
Old 01-06-2015, 10:36 PM
whd507's Avatar
whd507
whd507 is offline
I left it all at the store, I'll check tomorrow. I think it is an NCR unit, the slides are many and varied, but all ford.
  #244
Old 01-07-2015, 11:33 AM
Sailorf21's Avatar
Sailorf21
Sailorf21 is offline
1958 F600 VIN Info, Please
VIN - F60D8R25313
WB - 154
Color - E
Date - 01
Trans - 4
Axle - 44
GVW - 17,000
Net Hp - 149 @3600
D.S.O. - 2549
Engine block and intake is a 'mustard' color. Valve covers and aircleaner are white. It is a Firetruck with 3200 miles on it.
  #245
Old 01-07-2015, 03:28 PM
kip veltman's Avatar
kip veltman
kip veltman is offline
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Hi I have a1967 f 100 with a 6cy . I bought It used and not running I think It has the wrong flywheel the number on it is C7TE-A . Can tell me if this is correct or what the correct one is. thanks
  #246
Old 01-07-2015, 05:23 PM
NumberDummy
Originally Posted by kip veltman
Hi I have a 1967 F100 with a 6 cyl. I bought it used and not running.
It has the wrong flywheel, the number on it is C7TE-A
This is the Large Truck forum, please type further questions in the 1967/72 F100 and etc. forum.
C6TZ-6375-C . M/T Flywheel-164T / Marked: C7TE-A / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1966/68 Bronco 289 / 1969/79 F100 & Bronco 302 / 1975/79 F150 302.
Does your 1967 have a 10" or 11" clutch? The I-6 flywheel is specific to each.
  #247
Old 01-07-2015, 06:15 PM
kip veltman
11" clutch 300 I-6
  #248
Old 01-07-2015, 06:26 PM
NumberDummy
11" clutch 300 I-6
C5TZ-6375-N .. 240/300 I-6 M/T Flywheel - 164T - Use with 11" clutch / Marked: C7AE-C / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1965/66 F100/250 2WD // 1967/76 F100/350 3 or 4 speed / Ditto 1977 F100/350 before serial number Y20,001 // 1965/71 Galaxie/LTD 240 I-6.
I would think it's available from auto parts stores. There is 1 available NOS: MCDONALD OBSOLETE PARTS CO in Rockport IN = 812-359-4965.
  #249
Old 01-08-2015, 09:05 AM
38103Ford's Avatar
38103Ford
38103Ford is offline
Info please > VIN # <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <woNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <wontVertAlignCellWithSp/> <wontBreakConstrainedForcedTables/> <wontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="--"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDocument> </xml><![endif]-->2FTCR15Y3ECB22335
  #250
Old 01-08-2015, 11:45 AM
NumberDummy
I just attempted to decode your VIN - See your other thread in the correct (1980/86) forum. This is the Large Truck (500 and larger series trucks) forum.
  #251
Old 01-21-2015, 09:09 AM
jimbo42's Avatar
jimbo42
jimbo42 is offline
1963 F100 (wiper switch)
I have a wiper switch that does not work,,taken it apart several,,looks simple enough but still no electricity tru the switch,,,any exploded diagrams out there?,, or anyone have a good one for sale?,,thanks,,the ole fart Jimmy
  #252
Old 01-21-2015, 09:33 AM
jimbo42's Avatar
jimbo42
jimbo42 is offline
I am in need of a wiper switch for my 63 f100, jimmy
  #253
Old 01-21-2015, 10:04 AM
NumberDummy
Originally Posted by jimbo42
I have a wiper switch that does not work...taken it apart several times...looks simple enough but still no electricity thru the switch.
Any exploded diagrams out there? Or does anyone have a good one for sale? Thanks...the ole fart Jimmy
1963 F100: THREE different wiper switches. Is the wiper switch a single speed or a two speed?
If a single speed, does it have 4 terminals or 5 terminals?
btw: Please ask further questions in the 1961/66 F100 and etc. forum. This is the Large Truck forum for 500 and larger series trucks.
  #254
Old 01-21-2015, 10:21 AM
jimbo42's Avatar
jimbo42
jimbo42 is offline
wiper switch
mine has a total of 5 tabs,,power in and 4out
Are you 71 or older? If not, you're a 'young un' compared to me.
  #255
Old 01-21-2015, 04:02 PM
NumberDummy
C3TZ-17A553-G .. Single Speed Wiper Switch-5 terminals-Use with Ford wiper motor (Motorcraft SW-722) / Obsolete
Applications: 1963/66 F100/600.
No Ford dealer or obsolete vendor has any.
Quick Reply: OLD DECODES
