Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old 09-20-2013, 03:15 AM
m350's Avatar
m350
m350 is offline
Thank you for the info Bill ! This F700 with the 6.6 diesel 6-speed,ran/sounded healthy, un-fortunately found out it was 26,500 GVW needing a CDL to drive her,(don't have a CDL) it was a Bucket/material handler boom truck.
Going to look at a 1980 F700 Bucket truck today, Gas, lighter under CDL will post the vin, if you don't mind, if I am interested in it, thanks,,Mark
  #107
Old 09-20-2013, 09:34 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1980 (1957/80) trucks have an 11 digit VIN, does not contain GVWR info. 1957/79: GVW stamped by itself on 3rd line of Rating/Warranty Plate. 1980 uses a one year only paper label, should have the GVWR printed on it.
11 digit VIN: Series code (1st 3 digits) - Engine code (4th digit) - Assembly Plant code (5th digit). Last 6 digits is the Serial Number, the Numerical Sequence of Assembly, decodes to the year.
1981 thru today trucks have 17 digit VIN's that contain much more info, as you can see in my decode.
  #108
Old 09-22-2013, 02:20 PM
m350's Avatar
m350
m350 is offline
Hey Bill, OK looked at the 80' F700, ah too much Rot/Cheese and the hackers got there Hands on it !!
But on the way home we stopped at a truck we had seen last week, Got a hold of the owner, got to drive it, its a 82 or 83 F700 370 4V 23,100 GVW in nice shape Vin #
1FDNF70HXDVA18058 please if you can do your thing with that vin #, thanks,,Mark
PS this truck still also has the Hand manual E-Brake on the left side of the Cab that works good, Not the Power Hydraulic push button setup that I have heard horror stories about,, simpler is better in my Book !!
  #109
Old 09-22-2013, 04:27 PM
NumberDummy
VIN: 1FDNF70HXDVA18058
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
N = Class 6 (Hydraulic Brakes): 19,501-26,000 lbs. Gross Vehicle Weight Rating.
F70 = F700 (gas).
H = 370 (6.1L) 2V or 4V
X = Check digit, FoMoCo usage only.
D = 1983.
V = Kentucky Truck Assembly Plant.
A18058 = 1983 Numerical Sequence of Assembly, this F700's specific serial number.
  #110
Old 09-22-2013, 07:01 PM
m350's Avatar
m350
m350 is offline
Thanks for the info Bill !
  #111
Old 10-02-2013, 11:10 AM
Rlawmulching's Avatar
Rlawmulching
Rlawmulching is offline
hey bud, can you break this vin down for me please?
  #112
Old 10-14-2013, 12:58 PM
wkmcaregivers's Avatar
wkmcaregivers
wkmcaregivers is offline
i have a 1979 f600 4x4 with a 370 4v forged steel crankshaft and i am trying to find what is known as the "center member" or pto pulley that bolts to the vibration dampner to allow a pto shaft to couple to the crank. ford part # in 1980 was 6312. my understanding is it has been discontinued for 10+ yrs. can you help locate? if so please e-mail me at wkmcaregivers@yahoo.com. thank you
  #113
Old 12-19-2013, 07:49 PM
BobbyShane's Avatar
BobbyShane
BobbyShane is offline
Hello Bill
I haven't been on here in a while, a lot going on. What happened to ford truck enthusiasts? Looks like things changed a little. I don't know that I have been getting your posts in my e-mail in box for a little bit now.
I hope that all is well with you. By the way, a quick question: I have a 75 F250 Highboy. Will a rear sliding glass window work on trucks from my year through "97"? Thanks
Shane
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
  #114
Old 01-10-2014, 03:40 PM
sslyter's Avatar
sslyter
sslyter is offline
can you tell me the GVW from this VIN? 1FDXF8283JVA53242 I need to get a new data plate sticker and I know next to nothing about it, body color code, etc. Thank you.
  #115
Old 01-12-2014, 06:44 PM
Clem's Cousin's Avatar
Clem's Cousin
Clem's Cousin is offline
This VIN decoder: https://www.fleet.ford.com/maintenance/vin-decoder/ lists your truck as 26,001 - 33,000 lbs. GVW
  #116
Old 01-14-2014, 10:12 AM
jacobsjo87's Avatar
jacobsjo87
jacobsjo87 is offline
NumberDummy,
I'm looking for the part number and availibility of a 33 gallon fuel tank for a 1978 Bronco. So it would be a tank without the emissions stuff.
  #117
Old 01-17-2014, 10:31 AM
DodgeAddict's Avatar
DodgeAddict
DodgeAddict is offline
Here's my bucket truck VIN !FDNF70H0BVJAXXXX
  #118
Old 01-17-2014, 12:33 PM
NumberDummy
Originally Posted by jacobsjo87
NumberDummy,
D8TZ-9002-B .. 33 Gallon Fuel Tank-Use without CA emission / Obsolete
Application: 1978 Bronco.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
MANDERBACH FORD in Temple PA has ONE = 888-225-4364.
D8TZ-9002-C .. 33 Gallon Fuel Tank-1978: Use with CA emission / Obsolete
Applications: 1978 Bronco (CA emission) & 50 state 1979 Bronco.
GREEN SALES CO. has TWO.
If sold new in CA, the DSO code stamped on the Warranty Plate will be 71 or 72.
  #119
Old 01-21-2014, 07:59 PM
mikewv's Avatar
mikewv
mikewv is offline
f700 brake proportioning valve
Hi ND,
I hope you may be able to help me locate a part. I have a 1979 f700 that is in need of a rear brake proportioning valve. This truck does not have air brakes. If you need more info to find the part just let me know. The old one cracked and the repair shop I went to tried to weld it...poorly...need I say that didn't work AT ALL. Thanks!
  #120
Old 01-21-2014, 08:31 PM
NumberDummy
Originally Posted by mikewv
Hi ND,
I hope you may be able to help me locate a part. I have a 1979 F700 that is in need of a brake pressure differential (proportioning) valve.
Welcome to FTE
1969/72 F500/950 // 1973/77 F500 // 1973/79 F600/750 ~ Two different types:
C9TZ-2B257-A .. Brake Pressure Differential Valve-Use with split hydraulic vacuum brakes and dash mounted booster / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
No Ford Dealer, no other obsolete parts vendor has any.
C9TZ-2B257-B .. Brake Pressure Differential Valve-Use with split hydraulic vacuum brakes and frame mounted booster / Obsolete
POECS PARTS in Erie PA has 1 = 888-864-9305.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS has 2.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
VINTAGE PARTS INC. in Beaver Dam WI has 282 = 877-846-8243.
Quick Reply: OLD DECODES
