If you need any info - Page 6 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #76
Old 07-14-2013, 07:41 AM
bradinwnc bradinwnc is offline
bradinwnc is starting off with a positive reputation.
Thanks for the info. I was able to contact Chelsea and with the info you provide about the.truck was able to come up with a solution. Thanks again for the info.
Was wondering, where is the best place to go online for engine parts for this truck? I need to order ignition parts, points, condenser, etc.. if I was looking in the regular parts stores, like rock auto, which only shows parts up to a f500, should they be the same parts as long as engine is the same?
  #77
Old 07-14-2013, 11:59 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Why buy parts on the internet and pay shipping charges when local NAPA and indie auto parts stores sell the same parts.
  #78
Old 07-14-2013, 04:42 PM
True...Guess in just used to having to go that route when I'm looking for parts for my internationals...usually I have to find the right part number online then go to the local store and ordering the parts
Quote:
  #79
Old 07-14-2013, 04:59 PM
Quote:
Get yourself some 'Cornbinder' parts catalogs (try: faxonautolit.com), then type the part numbers into PartsVoice.com & rearcounter.com.
Registration is required for PartsVoice, not so with rearcounter. Searching for NOS parts is free on both sites.
1948 thru 1989 Ford truck parts catalogs are available on CD's from hipoparts.com
Here are samples of illustration and text pages from the 1973/79 Ford Heavy Truck Parts Catalog:
  #80
Old 07-14-2013, 05:17 PM
Thank you sir..any thoughts on where I could a wiring diagram for my truck? also, on the ignition wiring harness, I've got a wire hanging that pulses 12 volts on and off with the switch on, engine not running..any idea what it is?
  #81
Old 07-14-2013, 05:52 PM
Any thoughts on where I could get a wiring diagram for my truck?
Store located in Riverside CA .. Ed's not there on Saturday.
I know more about the Blue Ridge Parkway (it was closed north of Boone last time I was there) than I know about wiring, can look up the part numbers and that's about it.
  #82
Old 07-14-2013, 07:27 PM
My luck, local stor Ed, where I get parts (and a discount), only show up to an F500.. Can you give me coil, distributor, and related parts numbers(condenser, points, plugs, etc) till I can get a parts book..
  #83
Old 07-15-2013, 02:22 AM
My luck, local stor Ed, where I get parts (and a discount), same as F500.. Can you give me coil, distributor, and related parts numbers(condenser, points, plugs, etc) till I can get a parts book..
Points/condenser/rotor/cap same: V8 1958/73 Passenger Cars/Trucks, 1966/73 Bronco's, 1969/73 Econolines, ditto 1974/75's without DuraSpark electronic ignition.
500 and larger series trucks with FT engines didn't come with DuraSpark. FT engines cancelled at the end of the 1978 model run.
  #84
Old 07-15-2013, 02:54 AM
Thanks so much for your help, again.
  #85
Old 07-20-2013, 04:21 PM
Back for help again...need a new fuel pump...can I get one without the filter? Part numbers for original and replacement without filter?
Thanks
  #86
Old 07-21-2013, 12:18 AM
1976 F700 361 FT engine.
D4TZ-9350-B .. Carter Fuel Pump / Marked: D4TE-BA or BB (FoMoCo) & 6557-S or 6653-S (Carter) / Obsolete
1974/78 F600/800 and etc FT engines / Same: 1974/76 F100/350 360/390 FE engines / Same: 1974/77 F500 330 M/D FT engine.
Should be available from NAPA, indie autoparts stores.
Left: F600/800 & etc / Right: F100/350 & etc.
  #87
Old 07-22-2013, 09:40 PM
BigBlockFoodTruck's Avatar
BigBlockFoodTruck BigBlockFoodTruck is offline
BigBlockFoodTruck is starting off with a positive reputation.
Alright, NumberDummy, can I have you decode this one? E37AHCB2346
From what I know it's an Econoline built in 4/78 and shipped to Newmar Industries in Napannee, IN as an RV Cutaway.
  #88
Old 07-23-2013, 12:27 AM
Welcome to FTE
E37 = E350 Cutaway Cab.
A = 460 4V
H = Lorain OH Assembly Plant.
CB2346 = 1978.
  #89
Old 08-05-2013, 12:22 AM
Jim Lenna Jim Lenna is offline
Jim Lenna is starting off with a positive reputation.
How 'bout a 1997 F-800 VIN 1FTYF80C2VVA36955. Are any small parts available for the cab? Why is it so difficult to get parts for Ford trucks? No website I've visited so far supports an F-800 ):
  #90
Old 08-08-2013, 03:53 PM
Pete Kildow Pete Kildow is offline
Pete Kildow is starting off with a positive reputation.
U did it again. Spending my money. Ordered that CD of my truck glad you put that link up for those. Figure that is the best $27. I could spend.
Now I have that CD, Wiring Diagram, Spec book, 1987, 6.6 and 7.8 motor book. 1987 Shop and motor manuals Bod, Chassis and Electrical to look through also. Now If I could only read wiring digrams. These have to be in french as my redneck southern brain can't figure them out.
VIN there, done that (decoder needed...) Ste-Van Large Truck 17 03-02-2016 12:31 PM
Any place to Hot Tank parts in Greater Seattle Area? Sir.Dino 1957 - 1960 F100 & Larger F-Series Trucks 10 02-27-2015 10:39 AM
95 Remote Ignition Modules rainbowATF 1987 - 1996 F150 & Larger F-Series Trucks 2 08-25-2009 06:50 AM
He's Back.... FTE Jason Site Announcements 15 04-02-2008 12:10 PM
Discount Ford Parts Parts Guy Wyatt Vendor Specials, Discounts, Product Announcements & Group Buys 93 11-01-2007 02:34 PM
Tags
accessfreightliner, cards, cpd, dealer, ford, heavy, login, parts, sterling, syracuse, truck, tsl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
