Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old 06-24-2013, 07:22 PM
Tatum81's Avatar
Tatum81
Tatum81 is offline
I have 5 lugs, seem to be about an 8 inch pattern.
  #62
Old 06-24-2013, 10:20 PM
DragonPen999's Avatar
DragonPen999
DragonPen999 is offline
Nevermind, I'm an idiot that just made a $1000 mistake. Oh well least I can scrap it for a few bucks.
  #63
Old 06-25-2013, 01:09 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
You missed a set by a year:
https://www.ford-trucks.com/forums/1...8-pattern.html
Dodge motor homes had that pattern--5 on 8". They are 19.5 tubeless, which ends up with a little shorter tire than you probably have.
9R x 22.5s will work, but finding 5 on 8" 22.5 wheels is probably impossible.
5 on 8" split ring wheels with tube tires would be better than the Firestone wheels.
You mention "Budd" wheels. Budd is a wheel maker, and afaik, did not make the "widow maker" type wheel. HOWEVER, the widow maker Firestone wheels are the "Budd" type wheel, vs. the "Dayton" type wheel which is very different. Scroll down here for a brief explanation and pic:
what are budd wheels? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Do your rims have a split locking ring around the outside of the front wheel and the insides of the duals? Or is there a separation inside the wheel?
Ford two piece rims
Look at the video in post #4 here. My dad had a GMC 6x6 with these wheels, and he had the big ax-looking hammer to unseat the bead. What fun to change tires on that POS. (at least he bought a 1" impact for the lugs--finally)
Looking for the specific difference between "Split Rings" and "Split Rims/Widowmaker"
  #64
Old 06-25-2013, 01:36 AM
Tatum81's Avatar
Tatum81
Tatum81 is offline
Thanks for the thread references. My wheels don't have a split ring around the outer, they are a two piece rim that separate in the middle. Do you know any more about which years the dodge motor homes had my bolt pattern? Just so I can narrow my search. I appreciate all the info being shared.
  #65
Old 06-25-2013, 01:52 AM
85e150's Avatar
85e150
I'm thinking 1970s....
RESOURCES
  #66
Old 06-25-2013, 02:03 AM
Tatum81's Avatar
Tatum81
Tatum81 is offline
Thanks, I am using every angle I can to track down a set of "safe" wheels. I am really hoping to stick with something near the same size and not have to change the axles.
  #67
Old 06-25-2013, 08:24 PM
Tatum81's Avatar
Tatum81
Tatum81 is offline
If anyone is looking, there are two sets of 22.5 F600 rims on e bay right now... 6 lug, not 5. Maybe they are right for somebody.
  #68
Old 06-28-2013, 12:33 PM
Asparky112's Avatar
Asparky112
Asparky112 is offline
Hi I posted in another thread for a VIN decode but then saw this here so thought I maybe should post it here... 74 Ford F700 Gas dump 5/2 running gear from the ad so here is the Vin>>> VIN# F70EVU48354... Just wanting to know how easy engine parts are to get... Thus the reason for the decode..
Thanks
RON
  #69
Old 07-03-2013, 06:27 AM
72rustwarrior's Avatar
72rustwarrior
72rustwarrior is offline
HI NUmberDummy,
Can you tell me how the consecutive numbers are organized for the production runs and DSO options. MY Econoline has a VIN ending in "Q02422" Which looks to be the last of 1972's production it also has a special order DSO number of "1277" after the District code. (which I believe is the 1277th vehicle with Special Order Parts) Do those numbers refer to only the Econolines? the model within the Econolines? Or the whole production line in 1972? Any insight into how these codes were derived would be great. Can you look-up a model using the DSO code to find what it shipped with originally?
Thanks
  #70
Old 07-09-2013, 01:29 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Serial number (last 6 digits of VIN) apply to all series of 1948 and later trucks, 1961 and later Econolines, 1966 and later Bronco's.
6 digit DSO: First 2 decode to specific Ford District Sales Office that the dealer ordered the vehicle from.
Last 6 is the Domestic Special Order number. 1277 is related to your Econoline, but 1276 and 1278 could be any truck, Bronco, Econoline or a Passenger Car.
1972 serial number range: M40,001-Q00,000 / 1973 serial number range: Q00,001-S60,000.
Beginning 1970: Production date printed on the upper left corner of the Safety Standard Certification Label, glued to the B pillar below striker plate.
I have no way to get info for a Domestic Special Order, but you can get the info for a fee from martiauto.com
Late 1980's: FoMoCo was planning to THROW AWAY all the 1967/79 records. Kevin Marti, a Mustang/Shelby 'nut' in Phoenix AZ found out...and got ALL OF IT!
  #71
Old 07-09-2013, 07:26 AM
72rustwarrior
Thanks, I knew you would know this answer. I was wondering about the Marti report and if it was any good...
  #72
Old 07-09-2013, 07:45 AM
72rustwarrior
But I did see a Ford Shop-Tips somewhere that said Q20,000 was the start of 1973 for the econolines (page 10 Vol 11 #2) but on Page #9 the BRONCO 1973 started with Q00000.
  #73
Old 07-09-2013, 08:31 AM
NumberDummy
"I never saw a purple cow, I never hope to see one. But I can tell you, anyhow, I'd rather see than be one." -Gelett Burgess, famous San Francisco raconteur. Burgess was born...in Beantown.
Left/Right upper: 1972 / Left/Right lower: 1973.
  #74
Old 07-09-2013, 09:14 AM
72rustwarrior
Did the DSO affect the date? (like make production run later because of the special order?)
  #75
Old 07-09-2013, 09:15 AM
72rustwarrior
Also Mine was made (as I understand all Econolines were) made in Lorain, did the date code change per location of plant?
Quick Reply: OLD DECODES
